SOURCE: hotpoint built in dishwasher
Check your air gap on your kitchen sink. If equipped, you will most likely find it clogged. Pull off the metal cap, then unscrew the white or clear cap. You should find your clog there. Replace both caps and remember to pre-rinse the dishes better before loading.
SOURCE: Dishwasher will not go thru wash cycles
Hi
You have a problem which will need some knowledge of how the machine works and some test meter.There may be a problem with the motor.It may not beworking,jammed or dead -burnt out.The motor does the work after the water-cold,hot or medium-has entered.
The timer-you say works- will connect power to the motor to do its job,power to solonoid for the valves to open at the right time to let water in and out-pushed out by the motor.Remove the water with a cup and rags from the machine and then see if the motor turns by hand.This may mean you have to get under the machine.ALL WAYS REMOVE THE POWER CORD AT THE WALL POWER OUTLET--Jay
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
SOURCE: Dishwasher prog light is flashing and pump is running nothing els
ok, just a few minutes after posting this as a fault, I have opened the covers, the machine has a leak, the undertray has a sensor which has detected this, flashing light (prog 45 degC wash) flashing is a code to indicate leak sensor active.
Other prog lights flashing indicate a different fault, the following details each... this is a cut/paste from another forum site, copied without permission....
jawa592 on 6th Feb 2008
Cannot guarantee 100%accurate but you all might like
what the flashing fault codes actually refer to, note what follows are
pointers to what bit has gone wrong only. You should have the
programmes running left to right:
led1=intensive,led2=normal,led3=eco,led4=fast,led5=prewash,led6=delicate
wash.ok so when this heap of western european tosh goes wrong one or
two lights will flash this is what they mean:led3=m/ch has o/flowed
water . ie the base underneath has sensed a leak.4=i/let h2o valve u/s
or slow fill.5=thermister(electronic thermostat) is u/s or more likely
the pcb .6=timeout heating which means the thermister senser between
the door halves has become faulty or detached.3+4=no pump out,slow pump
out,pcb u/s,blockage.4+5=tap off i/let valve.3+5=wash motor not coming
on -seized,winding o/cic.but can also mean mesh plte filter badly
blocked.1+4software fault with pcb.4+6=heating cic u/s (usually the
heater tube )but can be the heater relay on pcb.3+4=pcb u/s.I don`t
except any responsiblity for this being spot on or near spot on!! hope
this helps someone.Try NOT to electrocute yourselves please!! If your
not at all confident walk away and get "someone" who knows what they
are doing.Cheers. jawa592
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
