Logitech Z313 Speakers stopped producing sound, I have tried playing music, the green bar showing music is moving (under the speaker button on windows 7), but the speakers are not giving off a sound.
Pretty much the same happened to me. There are two wires coming from the wired remote control. One has a green plug which plugs into your sound system (computer sound) and the other connects to the Sub Woofer assembly. Feel this later cable for a harden section. It will probably be closer to the Subwoofer, but may be anywhere along it. This cable will have been cooked by overheating (Playing sound at full volume for over long periods of time.) . You will feel probably a 6" to1' section that is a tad stiffer and the plastic will crumble. You will need to cut a few inches into the normal cable and remove the bad section. Then strip and tin, the cables and connect them individually . Connect (tin, solder and seal them individually: ground to ground, white to white, red to red, blue to blue, green to green, purple to purple). Depending on the electrical tape you use- there will be a thick bulge in the cord, but it should work fine... or you can connect the severed cable to the original source to avoid the bulge ... but I did not want to shorten my remote any more than I had to.
