Question about Sony MHC-GS300AV CD Shelf System
Sony 60 cd changer mhc-gs300av
When you turn on the stereo on the display screen it says press power protect what does this mean??
Posted by sods on
  • sallytynan Dec 10, 2007
    when you turn stereo on it says protect what does it mean
  • Djdan0731 Oct 26, 2008
    when you turn on the stereo on the display screen it says press power protect what does this mean?? and how do i fix it
Francisco Mauricio G
    Genius:
  • Sony Master
  • 1,550 Answers
The audio amplifier IC is damaged and need to be replaced
Posted on Feb 11, 2009
Water Damage/Power Protect...
Something has happened to it. Might be an IC fault. Seek assistance of any experienced service technician.
Jun 07, 2012 | Sony MHC-GS300AV CD Shelf System
What does it mean when your sony 60cd stereo system display screen says push protect
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 11, 2011 | Sony MHC-GS300AV CD Shelf System
Hi mysony stereo system is displaying push power protect on the screen and wont play nothing?can you tell me hat i have to push to like unlock it thanks:)
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Feb 22, 2011 | Sony MHC-GS300AV CD Shelf System
Push power protect
The audio amplifier IC are fried and need to be replaced
Nov 20, 2008 | Sony MHC-GS300AV CD Shelf System
Can i connect a mic??
No that is not really possible with this system nor would I recommend using it to record. What is it you are trying to record?
Thanks,
Lee
Jun 30, 2008 | Sony MHC-GS300AV CD Shelf System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Press Power Protect
Always be solved replace him the audio amplifier IC
Dec 30, 2007 | Sony MHC-GS300AV CD Shelf System
MHC-GS100 Shelf system
to restart, press stop, clear and display at the same time.
Nov 21, 2007 | Sony MHC-GS100 CD Shelf System
Sony MHC-GS300AV CD Shelf System Logo
1,402 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
