Question about Kenmore Washing Machines
Kenmore Series 400 Triple Action Agitator Washer restarts cycle after finishing
My washer gets to the end of the cycle, drains, and then instead of stopping has now begun restarting the whole cycle and begins refilling. Any ideas on what I can do? Thank you!
Posted by Steve on
Kimberly Walls
We have this exact problem. The repair guy told us it would be over $400 to replace the whole control panel. So for now we set a timer for 1 hour and if you are standing at the washer when it finishes you can open the door to prevent it from restarting. Until we get a new washer this is what we will do.
Posted on Sep 13, 2021
5 Related Answers
JR JR
Johnny Ramirez
  • 116 Answers
SOURCE: Kenmore Series 90 Washer Triple Action Agitator
THERE IS EITHER A 3/8 BOLT OR 1/2 ADAPTER TO REMOVE AGITATOR
Posted on Nov 30, 2008
Anonymous
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
Anonymous
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
Anonymous
  • 64 Answers
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Posted on Sep 21, 2009
Anonymous
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Posted on Jan 23, 2010
110.22954100 what is capacity of this Kenmore Washer
Kenmore 110 washer capacity
Washer. The Kenmore 70 series washer has a 3.5 cubic foot capacity. It comes with the Sears Triple Action agitator and can hold 28 extra-large t-shirts in a single load.
Kenmore Series 70 Specifications ' Hunker
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Kenmore 400 series washer won't finish cycle,I have to turn the dial to drain and spin to finish the load
Sounds like either a wire has come loose from the switch or the motor that spins the the ( may be integral part of switch ) has gone bad.
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
12helpful
2answers
1helpful
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
2answers
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
4helpful
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Washing Machines Logo
Michael Thomas
Michael Thomas
Paul Carew
Vernon Taylor
