Question about Electronics - Others
When I plug the USB cable to the labtop, no detection of device, installed the usb 2.0+3.0 drivers also. Also tried the rest of usb ports. On my older labtop has windows xp its there/
There are different reasons behind your USB cable not recognize such as:
for more help i will suggest you customer support help number +1 855-461-5433.
Posted on Jan 08, 2020
SOURCE: Logitech M-BJ58 USB optical mouse win xp issue
Hello dcipher,
This is due to a missing Windows file called input.inf. The solution is as follows:
In Windows XP, you can use the MSCONFIG utility as described in the following steps:
After extracting the file and restarting, try installing the mouse software again. You should no longer see this error message.
Note: The Windows XP .cab files are stored in the I386
folder on the Windows XP CD.
Should you have any further questions, please feel free to
post them here.
P.S. Before you assign a rating, please
make sure that the issue is resolved or you are satisfied. If not, please post
back as to what you did, and/or any other questions you may have, and I will
try to assist you as best I can. Please do not assign an ‘Inappropriate’ or
‘Thanks for trying’ rating if your issue is not resolved after the first
response itself, as sometimes a bit of to and fro dialogue may be necessary
before we can find a fix or an answer to
your query.
If you find that the solution/answer I provided led you
to, or resulted in a fix, please close the ticket with a FixYa! or Helpful
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Enjoy free
holidays, meals, shopping and more, with mystery shopping!! USA / UK
FREE SOFTWARE GIVEAWAY
Windows Utilities
Posted on Apr 25, 2008
SOURCE: Mecer Laptop USB port not detecting
Reset the Bios.That solved the same problem i had.
Posted on Feb 05, 2009
SOURCE: USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Posted on Aug 13, 2009
SOURCE: asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
Posted on Oct 14, 2009
SOURCE: I have a SONY NWZ-B142F It
Hello, please downloaded the driver at :
www.driverskit.com/MP3/Sony.html
www.sevenforums.com/.../9536-sony-mp3-player-new-drivers-rc-taking-over.html
www.computing.net > Forums > Windows XP
Posted on Feb 19, 2011
May 15, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Jul 18, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Mar 08, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Feb 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Jan 23, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Jan 22, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Oct 23, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Jul 07, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
May 04, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
374 people viewed this question
