Question about Midland Radio Communications
How to setup a Midland 77-285 CB radio - Midland Radio Communications
Posted by brad Mills on
5 Related Answers
Anonymous
  • 1139 Answers
SOURCE: midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
Posted on Sep 04, 2007
wyoed1
Ed Meshechek
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
wyoed1
Ed Meshechek
  • 211 Answers
SOURCE: midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
Mechanic688
Mechanic688
  • 204 Answers
SOURCE: look for schematics for a midland cb
daniel, first off, I need a complete model number for the radio info. Midland only made about 40-50 different models over the years. The header calls for a 75-822 and you are asking for a ** 833. The beginning should be a 13 or 75,76,77,78. Let me know the # and i'll be able to get you the proper pinout.
Thanks,,, Mechanic
Posted on Mar 08, 2008
Communicomm
David Eisenberg
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
Midland cb radio. when i turn on my wipers i get a noise over the cb radio
This is usually caused from a poor ground. Try to reground the radio to a better location and it should fix it.
Jan 06, 2011 | Midland 1001Z 40-Channels Base CB Radio
77-099 CB Radio: my midland just wont turn on anymore. is it a fuse...
hello you will not find an internal fuse though theres what we call a dummy or/reversed diode this is located at the rear of the radio beneath the top cover ,also check fuse along the radio line from battery to radio should be around 2-5amp fuse ,hope this helps
May 16, 2010 | Midland 77-099 CB Radio
Wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Sep 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland cb radio
NO. I SORRY. YOU COULD GET IT FROM THE MANUFACTUREE. THANK YOU
Sep 16, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland 75-822 CB
http://www.midlandradio.com/comersus/store/catalog/75_822.pdf
Mar 16, 2008 | Midland 75-822 40-Channels Handheld CB...
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Midland 75-822 40-Channels Handheld CB...
Radio Communications Logo
103 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
