Question about Canon PIXMA MP530 All-In-One InkJet Printer
I want to know how to assemble the Canon mp530 sheet feed unit. Please.
Posted by JONG MIN Lee on
  • JONG MIN Lee
    JONG MIN Lee Apr 23, 2017
    The motor inside the printer has failed and the sheet feed unit has been replaced.
    I know that when the printer is turned on, four motors are driven sequentially. The bottom roller is running, but the motor that feeds the paper is caught by the gear wheels, stopping while making noise, and the carriage motor will not work either.
    If you know how to assemble this part (Canon mp530 printer), I would appreciate any help. It takes about 2 hours and 30 minutes when a skilled technician assembles it.
5 Related Answers
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: Canon MP530 ADF
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
Anonymous
  • 1185 Answers
SOURCE: Loose screw jamming paper in Canon Pixma MP530 printer
Go buy a magnetic retriever from your local hardware shop they are very cheap.
Make sure you get a slim version
Either that or turn the printer upside down and get someone to whack it on the bottom with the palm of their hand as you hold it
What goes in must come out
Posted on Jul 06, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: canon M P 800
Hi
All the best
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: I paid for the premium Fixya plan for theM P 800 canon
Hi
Try it
Solution 1:
Solution 2:
Solution 3:
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: With my canon mp530 the paper will not feed into
Does it make the sounds as if it is trying to grab a sheet of paper and just will not? Try unplugging the printer from the power source for at least 2 minutes, then replugging it in. Try just a single sheet of paper in the paper tray. See if it will at least grab that.
Let me know what you find, just reply here!
Thanks
Tim
Posted on Oct 25, 2010
Canon MP530, would only print half of a page then quit and give me error message 5700. I would pull the paper out and shut down and would start and print only half of a page and stop. I would take out...
This error is referring to the ASF assy (Assembly frame which means the paper feed section)
This paper sheet feeder assy is a extremley complicated piece and is therefore not really repairable. You will need to take the machine to a canon repairer for a new assy sheet feeder to be fitted. It takes a trained engineer about 2-1/2 hours to fit one as the whole machine has to come apart and the new feeder has to be aligned while fitting. Its a job i always hate having to do. You dont have any other options i am afraid. Srri to bring you such bad news.
May 24, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The orange "Alarm" light keeps
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. According to the service manual you will need to replace the sheet feed unit, logic board assy, purge unit.
Feb 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
6A00 error code
Unfortunitly this isnt an easy fix. IF you still have it under warranty you can contact Canon and the ywill fix it. If its not under warranty they can refer you to the nearest Canon repair center.
- Sheet feed unit
- Logic board
- Purge unit
Best of luck..
Nov 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Says Check printer 6A00. Any ideas?
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
May 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My canon ix4000 gives a service error 5750 - Could you please help
its a ps cam sensor error, check the sheet feed unit, replace logic board assembly, check output support unit, check output support gear unit
Aug 16, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Display Shows Error 6A00 and it Doesnt Work ahead
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Jun 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 ADF
Jan 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hi
Try it
Solution 1:
Solution 2:
Solution 3:
Nov 16, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
