Question about HTC Computers & Internet
Do you know a way, place or anything to unlock a password on an Android 5.0 os, htc one max. Tried all the posted options and nothing so far.
No gmail option, and dont want a hard rest.
4 Suggested Answers
yngwei50
yngwei50
  • 134 Answers
SOURCE: i dont know my dell inspiron e1505 admin password,
The only way to reset the Admin password is through SAM database, first you need to create a USB bootable drive and download password reset program (it's DOS base) after you've created a USB bootable drive put the password reset program there and boot your PC to USB and type the password reset program name, and you are ready to reset the administrator password.
Posted on Oct 30, 2009
Testimonial: "Awesome, Thank you"
John Cunningham
  • 6771 Answers
SOURCE: how to unlock toshiba satellite laptop BIOS and HDD
If you are the original owner Toshiba will reset the bios for a fee and it is not cheap, they may include the HDD reset, if not! www.ebay.com type password, or hard drive password. I would check bios password, probably a lot cheaper if you can find the right seller, also check www.download.com some software may be free.
Posted on Mar 22, 2012
Jenn Lee
  • 6 Answers
SOURCE: i have a bluechip android phone,my son locked it,it says i need my google account user name and password,wnich i dont know because i have never needed it
This is a common problem, where you input the correct name and password and it still doesn't work. To solve this: Try going to this site from your PC: https://www.google.com/accounts/UnlockCaptcha Put in your info and it should say device unlocked Re-enter your info into your phone and it should take you to a new screen to set a new pattern and once you set it your phone should be unlocked. After you unlock your phone, you can take off the pattern unlock in the settings.
Posted on Apr 28, 2012
SOURCE: how to unlock htc droid incredible 2
i don't think you can because then any one could hack into the phone . besides verizon is the best cell phone company i have ever used . so why not use them for cell phone, internet whatever you need i could talk to my boss from honey brook pa all the way to barksdale lueseana and moutaintop pa and even talk to my dad in berks county pa from washington state in a 18 wheeler in the moutains with perfect reception . carrson mccleary
Posted on Apr 30, 2012
Unlock pattern
Why is it not accepting your gmail account? Dont you remember which Gmail account you used to start using the Android phone? As far as I know, there is no "reset" to this. You will have to reinstall the OS. Connect your phone to the PC and look for update of Android version. If there is no update, you will have to "ROOT" your android phone. There are many many tutorials online on how to do that. But it is risky and if you mess anything up it might BRICK YOUR PHONE. Meaning, your phone will become nothing more than a paper weight.
Best thing is to remember the gmail account that was used and follow the steps. I have done this and it was pretty straight forward.
Oct 01, 2013 | Sony Cell Phones
How to unlock pattern for samsung shw-m110s
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nov 03, 2012 | Samsung Cell Phones
My htc is lockd it can make emergency calls only and i forgot my password
It says Emergency Calls means it locked to Network Lock,You need to Unlock it from Network Lock,You can get the Unlock code at
http://www.mobileunlocksolutions.com/htc-touch-hd/rs1wp9/ and Unlock it,Then You can get the password code from service provider as free of cost,.
Apr 13, 2011 | HTC Cell Phones
I have forgotton my lock screen pattern, how do i get my gmail and password?
lock screen pattern and gmail password is not related. but if you forgot the lock pattern u can reset or disable it with gmail id and password. If you draw the incorrect pattern five times you will get a message press OK. u can see a new button on screen below the pattern named "forgot pattern?". Touch this button to reset or remove the pattern with gmail id and password.
Mar 18, 2011 | HTC Wildfire Cell Phone
My son had my phone and somehow put a pattern lock, is there anyway you can tell me how to reset it, or unlock it?
Your's is an Android mobile phone I believe.
For Andorids with the Pattern lock, if you try the wrong pattern 5 times, you are given the option to use your Gmail account to unlock and reset your Android device unlock pattern.
Once you get the prompt for the Gmail login, use the account that you have set up in your Android device. This would take you to the option of resetting the unlock pattern.
Please note that if you have set up the 2-step-verification for Google accounts, your password will not be the regular Gmail password. You'll have to generate the authorizing password here: https://www.google.com/accounts/IssuedAuthSubTokens
Hope it helps. If so, please consider rating this solution.
-regards,
M
Mar 13, 2011 | Motorola Mobility CLIQ Cell Phone
I for got my lock pattern
Yours seem like an Android mobile phone.
For Andorids with the Pattern lock, if you try the wrong pattern 5 times, you are given the option to use your Gmail Account to unlock and reset your Android device unlock pattern.
-regards,
M
Mar 09, 2011 | Samsung Cell Phones
I got my pattern code wroung on my samsung galxy 19000 now its lock
Get your account password wrong 5 times and it will ask you if you forgot your password at the bottom. Then it gives you the opportunity to unlock your phone using your Google account credentials.
Mar 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
My vodafone 845 got locked with the grid password an dnow i cant unlock it my kids locked it and they forgot the passwork . how do i fix it?
Yours seems like an Android phone. For Andorids with the Pattern lock (I assume that's what you meant by grid lock), if you try the wrong pattern 5 times, you are given the option to use your Gmail Account to unlock and reset your Android device unlock pattern.
Hope it helps.
-regards,
Mrigs
Mar 03, 2011 | Vodafone Cell Phones
How do i get into my android when i forgot the finger pattern cod
Keep trying the finger code until it tells you have done it too many times. After that it will ask for your Gmail address and password and then you will be able to get into your phone.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
Jan 13, 2011 | Google Android
Sprint TP2 with no data
well, this is obviously not an Android handset. however I have a TP2 on Sprint and run Android as well and I get data and wifi.
I would suggest going back to the forums where the developers are working on this stuff (ie: ppcgeeks dot com, etc) and grab a newer copy.
your inquiry is obviously not supported but it does work (with GPS too). There's still no main speaker nor camera, etc but I can totally get/ use data, google maps (sucks without sound but whatever).
you likely know you can also update your OS to WM6.5 and the new Bing has navigation integrated and it's actually pretty good
Jun 03, 2010 | HTC Touch Pro2 Smartphone
Computers & Internet Logo
29 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
DADA BHAI THAKUR
DADA BHAI THAKUR
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
