SOURCE: my american standard jacuzzi tub
check the air tubing coming off the back of the motor. that tubing should connect from the air switch on the motor to the bottom of the air button on the top of your tub.
if it is not connected then it will never turn on.
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
SOURCE: My American standard Jacuzzi tub hums when the button is pushed, but the jets do not turn on
Trey, motor or pump is seized, have tech. take a look and repair.
