Question about PfaFF Sewing Machines
Changing presser foot pressure on Pfaff 2054 - PfaFF Sewing Machines
Posted by Sheila Sekula on
R.A. Ellis
  • PfaFF Master
  • 12,731 Answers
Posted on Apr 09, 2017
Error message on Pfaff 7570 is "bring presser foot lifter to sewing position?" Is this a fatal error or is this a procedure that has to be done before the machine will operate?
Assuming that the presser foot lifter is working, this shouldn't be a fatal error. The presser foot has to be down to sew. The lifter needs to be in the down position to put the foot down.
The manual for the Pfaff Creative 7570 is available on the product page: http://www.pfaff.com/en-US/Machines/creative-7570 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_7570-manual-EN.pdf?ext=.pdf . See page 32 (page 36 of the PDF) of the manual to see a picture of the presser foot lifter.
I hope this helps.
May 27, 2018 | PfaFF Sewing Machines
I have a quilt expression 2044 and need a free motion quilt foot, 93-036 963-91/00. I went to a shop that sells pfaff and they said it is no longer available.
Although the dealer may no longer sell the "original" foot for your machine, there are usually "used" presser feet available from sites like eBay. OR, you can purchase non-Pfaff presser feet that will work just as well on your machine. Just be sure to verify that the presser foot is compatible with your model (the shank style will determine whether it will work on your machine).
Pfaff Free Motion Open Toe Quilting Foot
Free Motion Darning Foot Pfaff 820243096
Pfaff Presser Feet
Aug 27, 2017 | PfaFF Sewing Machines
Pfaff 7550 presser foot will not go all the way down after using darning foot and returning to regular sewing.
By chance, do you still have the darning foot on the machine? If so, it is shorter than a regular foot which allows space to manually maneuver the fabric.
Also check that the presser foot pressure is activated and the feed dogs are in the up position.
Sep 06, 2016 | PfaFF Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
Pfaff 7550 pressure foot
The presser adjustment is usually above the presser foot near the top of the machine.
It can be a post on the top of the machine, a chrome screw on the top of the machine.
Check with your Pfaff dealer.
I use the walking foot for this technique...no puckers if the quilt is first basted.
Mar 18, 2010 | PfaFF Creative 7570
Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Dec 31, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
218 people viewed this question
Top PfaFF Sewing Machines Experts
Irene Tulloch
Asmodius
Level 1 Expert
Chris Wetmore
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
