Firearms Logo
Mark Kerxhalli Posted on Apr 07, 2017
Where can I find base pads about 3/8" thick for a S&W model 41 magazine?
The grips on the S&W model 41 are cut so that they act like a mag well and the mags need to be pushed up into the gun with just a couple of fingers instead of your palm
Larry Hill
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 21, 2017
Larry Hill
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
136
Points
I was unable to locate a replacement base for the magazine, but used to when mag wells were added to 1911s, we would glue a piece of hard rubber or plastic to the base. You may have to shape it to match up. Easy fix if you have the materials.
How do I tell if my Cooey model 64b takes a plastic or metal mag?
These all say steel
Savage Lakefield Cooey 64 Steel Magazines ' The Gun Dealer
https://thegundealer.net > product > savage-lakefield-co...
10-round replacement steel magazine for semi-automatic Savage, Lakefield and Cooey 64B firearms. Note: Does not fit older firearms with plastic magazines.
$28.99 · ‎In stock
Savage, Lakefield, Cooey 64b Magazine - MARSTAR CANADA
https://marstar.ca > ... > Rifle Magazines > Other
10 round replacement steel magazine for semi-automatic Savage, Lakefield and Cooey 64B firearms. Seldom seen and hard to find. Get that old Cooey out of ...
Winchester Cooey 64 Parts ' Gun Parts Corp.
https://www.gunpartscorp.com > cooey-series > cooey-64
Browse the large selection of Cooey 64 products offered by Numrich Gun Parts. ... Model: COOEY 64, COOEY 64B, COOEY 64B DELUXE. Product #: 991960C.
Jun 15, 2021 • Firearms
I have a Ruger m77 MARK2 300 win mag it dents the bullets and scratches them every so often how do I just it so it won't do it???
Is it denting the projectile or the cartridge case?
Look for burrs or sharp edges in the magazine or on the ejector. Work the action slowly with dummy rounds so you can see the cartridge moving through your rifle's action - also look at the chamber mouth to see if there is a shard of metal here where it shouldn't be.
May 02, 2019 • Firearms
Just bought new dan Wesson lcp45 and magazine will not lock in mag well
Remove one round from the magazine and try it again. If it is still not retaining the mag, then you have a problem with the magazine catch. Also try a different magazine as there could be a problem with the mag catch notch in the magazine. In any case this is not a user repairable item. Take this to your local gunsmith or back to the dealer you purchased it from.
Jan 05, 2019 • Firearms
2answers
Can a norico 9mm mag load more then 16 shots
No, not when it comes to Norinco magazines for pistols, at least.
The single stack version holds up to eight rounds and the double stack version holds up to 16 rounds.
There are other 9mm magazines (AR-15), however, that can hold up to 32 rounds. Here are some of them: https://www.cheaperthandirt.com/category/parts-and-accessories/magazines/ar-15-magazines/9mm-mags.do
Jan 04, 2019 • Firearms
The last bullet in the tube of my model 60 marlin won't slide in to load. all other bullets other than the last one load and fire. the last bullet can be hand loaded and will fire
Could need a new spring in the magazine tube.
Ebay has complete inner magazine tubes.
search for Marlin Model 60 .22 Inner Magazine Tube
Aug 20, 2018 • Firearms
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 • Firearms
Top Firearms Experts
vince
jws1013
Kolbrun...
Are you a Firearm Expert? Answer questions, earn points and help others
