Question about Toshiba Cameras
I have a Toshiba PDR2300. I get card error and can't take pictures. How do I fix this?
  • Toshiba Master
  • 6,229 Answers
Discover what the error is with the card and correct it. The card could be corrupted, an incorrect storage capacity, write-protect could be set, or it could be full.
Posted on Apr 08, 2017
PDR2300 card error
Why ask twice ?
Apr 07, 2017 | Cameras
How do I get my pictures to transferfrom my tablet to my laptop after an error code E0000225
t is difficult to face Windows update error E0000225 on your computer. While installing Windows updates or when you click for updates then you might have to face Windows stop error E0000225. This update error shows that there is some problem occurred while updating Windows operating system. To proceed the update process you must have to fix this problem first which is possible with automatic Windows error repair tool.
Source :http://cricbuzzlivescore.com/ Cricbuzz Live Score Cric Buzz App Download Cricbuzz Live Score
Nov 21, 2016 | Tablets & eReaders
Memory Card Error
You could take the card to a store that has a Kodak picture maker machine (Walmart, etc.). From there, you can print your pics or even make a cd of them. The card may be faulty or just may not work in Canon cameras.
Aug 28, 2009 | Canon PowerShot A520 Digital Camera
Card Error
Are you getting this error with the card?
If so, insert the card into the computer. Make sure you get all the files off before you continue. Then go to my computer, right click on the drive, click properties, click the tools tab and click check now. Just do Automatically fix file system errors and click start. This should successfully find errors if present on the card and fix it. You may lose a picture or two if you don't transfer all of them first. Or you could format the card by right clicking on the card drive and clicking format.
If you get the error on the camera without the card in it, turn it on and click mode button twice to get to the picture display (it should be a black screen with "memory error" on top). Then press menu and use the 4-way button to go to the right for Setup. Then use the 4-way button to go down to format to format the camera.
This should fix it.
May 05, 2009 | Sanyo VPC-S880 Digital Camera
THE LENS OPENS AND CLOSES QUICKLY DOES NOT LET ME TAKE PICTURES EXS880
Two possible solutions:
1: Lens Error----If the camera powers on and then beeps a few times and then powers right back off.
Same as above but might also say "lens error" before shutting off.
2: Wrong size memory card --------The EXS880 can take up to a 1 gb memory card right out of the box. If you try to use a memory card larger than that you will have to see if there is a firmware upgrade available. Also Casio only recommends 3 brands of memory cards, they are Toshiba, Panasonic and Sandisc. Using any other kind can make your camera act funny.
If it is a lens error the only way to correct that is to send it into repairs. I would first make sure you are using the correct memory card. If you are then you have no choice but to send in and have it fixed.
Sep 12, 2008 | Casio Exilim EX-S880 Digital Camera
Olympus 770 not able to move photos from xd card to laptop error message every time
A couple of questions :
What happens when you use "Windows Explorer" to view the contents of the card .
It should appear as just another disk drive in the list .
Are you able to view the contents of the card when you plug the camera into the usb port ?
Dec 04, 2007 | Olympus Stylus 770 SW Digital Camera
Memory Card Error after Airport Security
In suitcase? Checked baggage? Bad idea. Here's why. I damaged an LCD display that way. Not cracked or broken, but the baggage area is not a heated or insulated space. The temperature can reach well below -40 F (or C). Most electronics is not rated for such and my LCD on the device I put in my checked luggage shows the effect. Lesson learned firsthand....
Sep 15, 2005 | Toshiba PDR-M25 Digital Camera
Cameras Logo
Top Toshiba Cameras Experts
Ekse
Lawrence Oravetz
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
