Replumb the outlet for the dishwasher into a different drainpipe. The installer put your dishwasher outlet onto your garbage grinder outlet.
If there is only one drain pipe under your sink then things get difficult.
You can try to lift the outlet hose from the washing machine a little bit but that might cause problems in your dishwasher.
A backflow valve on your dishwasher outlet might work if there is one available.
Check you drain is not blocked slighty (highly likely with a garbage disposal) and causing back pressure. Draino; Boiling Hot water; bicarb and vinegar,
Was it working properly a while ago?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
