Question about Element Electronics Televison & Video
I need remote code for Element Electronics EDVD1080p for a universal remote control. I live in Germany and this company is not known. We have a lot of American dvds.
Posted by Genevieve Schetagne on
5 Related Answers
Anonymous
SOURCE: Element LCD TV FLX-3210
Try 004. That worked for me
Posted on Jan 02, 2008
Anonymous
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
Anonymous
SOURCE: Need 3-digit code for tv remote
I'm looing for the TV brand to choose so I can find the right 4-digit code for an Element TV (Element is not listed)
Posted on Nov 07, 2008
Anonymous
SOURCE: universal remote control code
I have a Dynex t.v, but my remot control doesn't work .
Posted on Apr 25, 2009
Anonymous
SOURCE: need codes for universal electronics remote that will oporate tx-sr606receiver
I have the same problem and from what I've read elsewhere there is not a cheap and easy solution. From what I gather, simple remotes (like what you get w/ your set top box) that use manufacturer's codes for programming treat "on" and "off" as a simple toggle. That means they fire out a singal signal which is supposed to simply change the state of the device from off to on or vice versa. The Onkyo apparently uses different signals for on and off. Because of this we will need to get a "learning remote" which can be programmed to provide a separate signal for any desired function. These tend to be much more expensive which is why they don't just give them out with your set top box. Right now I'm still fiddling with separate remotes until I break down and drop the bucks for the special remote.
Posted on Jun 03, 2009
Need universal remote control code for digitor tv g4321
I don't know where you live. Try Jaycar Electronics or a Dick Smith or similar type electronics store. Some Retailers sell generic universal TV remotes as well.
Nov 22, 2017 | Universal Remote Control Televison & Video
Find the a new control for my element tv
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Oct 16, 2014 | Element Electronics Televison & Video
How can I program a directv remote to operate tv 40" led tv ?
Marion, Check the attached links,instruction and guides to program direct TV remote. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://manuals.solidsignal.com/directvrc64forweb.pdf
How to program your DirecTV universal remote to your TV with just one...
Remote Control Codes For Element TVs Codes For Universal Remotes
May 19, 2014 | Element Electronics 40 in. LED HDTV
Programing att universal remote
Frankly I doubt the ATT remote with the limited number of codes will even program for this set, see if the remote has a search mode which would allow you to try each and every code in it one at a time.
Dec 22, 2012 | Element Electronics Televison & Video
Code number
hi . you could try ge brand or philips brand universal remote control in code#1173 or auto code search. maybe working your element lcd tv. good luck!
Sep 03, 2012 | Element Electronics Televison & Video
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Need code for remote. New remote needs replacing.
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
May 09, 2009 | Element ELC-HS321 32 in. LCD TV
Televison & Video Logo
52 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
