Question about Schlage Locks & Locksmithing
Schlage Cobra MPC lock will not lock or reset. Both red and green light flash a single time when pressing any button.
This problem first occurred last week and Schlage help desk couldn't assist so I purchased another lock (same model) which worked for a week and then started the same behavior. Any help would be appreciated.
Posted by Rich Baker on
5 Related Answers
Anonymous
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Posted on Jan 08, 2008
irsheye
  • 323 Answers
SOURCE: Hello, We need some assistance
hold the start button for 3-4 seconds and see what that does
Posted on Jul 04, 2009
Anonymous
  • 952 Answers
SOURCE: Phone won't open, red light flashing.
bring your phone to a local repair shop and have the ROM erased then have the phone software reinstalled.
Posted on Jul 09, 2009
Anonymous
  • 96 Answers
SOURCE: power and internet lights flash slowly green &
Try a hardware reset by holding in the reset button on the back panel (need a pin) for 20 seconds as you turn it on. If it does not work or you will not get connection from your router to cmputer it means the router has gone bad and need a replacement Let me know if this will help
Posted on Nov 27, 2009
Coaltowner
  • 963 Answers
SOURCE: My schlage lock isn't responding. the battery has
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Good luck--and please provide feedback if this helps!
Posted on Nov 08, 2011
Schlage model be365 working backwards I need to put code in for locking but to unlock only have to press Schlage button, please help
The timing is off. Remove the lock again. Pull out the directions where it told you to install with timing mark set just so...and move things to that position and reinstall lock. Not a big problem to have and it should only take a minute to correct. Have fun!
Dec 18, 2016 | Schlage Locks & Locksmithing
Can i purchase multiple keypad deadbolt with same key?
Yes, Thank you for your inquiry; At FactoryLocks.com we carry Schlage BE365PLY505. The key number is stamped on the key. You can purchase the same entry on our website, factorylocks.com with your existing locks key number. Enter the 5 digit key code on our shopping page that is on the key. We'll get it keyed and out to you quickly.
May 09, 2014 | SCHLAGE LOCK COMPANY Schlage BE365VPLY505...
The switch that unlocks my schlage FE595 door lock from the inside needs changed and I can't find a replacement.
Schlage's warranty policy covers the electronics for 1 year to the original purchaser. Last week I answered another question about buying the keypad assembly for a Schlage lock. Here's his experience:
"I had commented on their site about no spare parts being available and one of their reps contacted me and says they are going to replace the lock for me. This is a very generous gesture on their part and if it comes thru, will be a great deal for me. However, the problem still remains that there are no parts available for the other people that have this same problem. The locks have a lifetime warranty on the finish and mechanism but the electronics only have a 1 year guarantee...."
I suggest that you contact Schlage, but you will probably find that you can't buy the switch you need. Plead your case, ask to have it elevated, make a negative comment on their website like the other gent did.
Here's the contact information:
Go to Schlage.com Click on :"For your Home", then "Service & Support", and under that "Contact Us"
Feb 26, 2012 | Schlage FE595-CAM-ACC FE595CAM620ACC...
Schlage deadbolt
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
You also need to check the operation with the door open versus the door closed--to make sure that you haven't developed a mechanical bind between the door and doorjamb. If all else fails, the lock should be under warranty!
Jan 26, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
I've had the same fault 3 times now in the last 3 weeks."Door" flashing fault.Firstly,the engineer replaced the door lock. Fault occurred again a week later,so he replaced PCB board,but fault...
I need some more information to the brand and model number to assist you. Please get back to me and I will help you the best way possible.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 09, 2011 | Washing Machines
My residential schlage cobra lock no longer locks. I have checked the batteries. Using the programming instructions, I cannot get a "normal' code to program. I always get flashing lights...
Since you seem to be doing everything properly and following the instructions, I recommend that you contact Schlage for some technical assistance. Here is the contact information:
Olathe, KS 66061
Schlage FAQ:
Aug 04, 2011 | Schlage COBRA by Keyless Lock
I don't know the model number of the lock. It was installed in 1993.The latch broke. I got a new latch but cannot get it to work. Either it won't go or the handle slips. It does not have a key....
Start on this web page to identify your lock:
http://consumer.schlage.com/Products/Pages/category-landing.aspx?category=Electronic+Security
Then go to this page for links to the proper instruction and programming manuals and videos for your lock:
If you're still having a problem or need parts, here is the contact information for Schlage Customer Service:
Olathe, KS 66061
Hope this helps!
Jun 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
I have a two month old Schlage door lock recently I went to get a new copy of Schlage keys. I tried it one time it work and a week pass suddenly my new keys doesn't work and even the original key, it...
Hello My name is Lori and I work at Schlage Customer Service. If this is not a Schlage Key it may be possible that they did not cut the key to the correct code. Look on your key for the 5-digit key code and make sure the keys align up exactly - the keys also should be the same width. Also when you install this B362 you should install it with the katch extended and the keys out of the cylinder. Try some of these tips and if you still need help - please feel free to call us at Schlage Customer Service: 1-888-805-9837 Good Luck!
May 13, 2011 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I just installed last week with new included battery and twice since The push pad was non responsive. I play with it for a minute or so and then the number pad lights and sound comes back and door...
Assuming you've followed the installation directions accurately and do not have a mechanical bind within the lock or between the lock and strike plate (how does it operate when cycled with the door open?). Beyond that, I'd exchange the lock with a new one.
On this page you will find videos of how to install and how to program your lock:
If all else fails, here is a link to the customer service contact page:
Apr 18, 2011 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
Locks & Locksmithing Logo
597 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
