Question about Hamilton Beach Kitchen Appliances - Others
Hamilton beach rice cooker, 10 cup
Mearument for cooking rice
Posted by Patricia... on
5 Related Answers
Anonymous
  • 98 Answers
SOURCE: 6 cup rice cooker
its very easy if you put 6 cups of rice= 6 cups of water
5 cups rice = 5 cups water ...equal proportion
Posted on Feb 11, 2008
Anonymous
  • 487 Answers
SOURCE: farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
Posted on Jun 24, 2008
Anonymous
  • 141 Answers
SOURCE: hamilton beach 20 cup rice cooker
The rice cooker should have markings on the side of the pot. This indicates the water level for a given amount of rice. For instance, if you add 4 cups of rice, you add water until it is level with the 4 mark.
Posted on Sep 15, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
Posted on Feb 27, 2009
Anonymous
SOURCE: I need the instruction manual for a wolfgand puck 7 cup rice cooker Model #BDRC0007. I don't know how to cook the rice.
I had to find it on the Wolfgang Puck website, this is a direct link to the PDF file
http://www.wpcookware.com/instructions/BDRC0010.pdf
Posted on May 06, 2009
Your Sauerbraten recipe out of your Hamilton Beach Easy Serve-Easy Clean Removable Liner 6 qt. slow Cooker recipe book that came with my crock pot over 20 years ago.
Ingredients Recommended Hamilton Beach® Product:
Slow Cooker - 5 or 6 Quart Size
  • 3/4 cup white vinegar
  • 1/4 cup ketchup
  • 1/2 cup frozen chopped onion
  • 1 teaspoon chopped garlic
  • 2 cans (14 oz. each) beef broth
  • 1 teaspoon sugar
  • 12 ginger snap cookies
  • 2 envelopes (0.8 oz. each) brown gravy
  • 1 (4 to 5 lbs.) boneless chuck or bottom round roast
Directions
  1. Combine all ingredients, except the meat, in the slow cooker. Stir well.
  2. Add the meat and stir well to coat.
  3. Cover and cook on preferred setting:
    • Low - 10 hours
    • High - 5 hours
-Visit www.foodsafety.gov for more information.
Serves: 8-10 German Style Pot Roast Recipe Find More Recipes for Slow Cookers from...
Sep 26, 2018 | Hamilton Beach Crock Pots & Slow Cookers
Tip
Rice cooking
This morning I have encountered a great many questions on rice cookers, so I remembered the time when I had one and why I started cooking rice again.
The rice was beautifully cooked in the cooker, but it took up too much space on my kitchen bench. So I turned to pots and the micro.
Cooking rice in a microwave
  • take 1cup water
  • 2 cups rice
  • a pinch of salt
  • put the water, salt and rice together in a bowl with a lid
  • blend well
  • put the lid on the bowl
  • put the bowl into the micro
  • on the micro, keep full force and set the timer on five minutes
  • start the cooking
  • after five minutes open the micro, open the bowl and stir the rice with a fork.put the lid on again keep the micro going for another 10 minutes.
  • repeat the stirring prosess, until the rice is nice and fluffy andready to serve.
Cooking rice in a pot with a lid.
  • take 1cup water
  • 2cups of rice
  • pinch of salt
  • put the ingridience in a pot, and an oven safe pan
  • in the pot, now with a tight lid. Put on a cooker on highest temperature for five minutes.
  • open the pot, stir the rice with a fork.
  • lower heat and cook for another 15-20 minutes,, stirring occasionally.
  • the rice is cooked when fluffy.
Cooking rice in a pan in the oven
  • Put the temperature in the oven on 150 degrees Celsius
  • put the ingridience as in the recipe above in a pot and start boiling
  • remove from pot into a ovesafe bowl or pan
  • Cover bowl/pan and cook further for another. 20 minutes.
on Aug 12, 2015 | Miscellaneous
How much water to one half cup of jasmine rice
Hello, Steve -
If you are cooking the jasmine rice the traditional way on a stove, the ratio of rice to water is:
3/4 cups of water to 1/2 cup of rice (per most instructions on packages); for softer rice, add just a little bit more water, plus it is recommended to rinse the rice and drain it prior to cooking
See:
https://www.onceuponachef.com/recipes/perfect-jasmine-rice.html
If you are using an electric rice cooker, the rice to water ration is:
1/2 cup of rice to 1/2 cup of water; rinse and drain the rice prior to cooking
See:
https://www.wikihow.com/Make-Jasmine-Rice-in-a-Rice-Cooker
Best wishes.
May 01, 2018 | Cooking
Lost instructions
Here you go . . .
The manual: http://www.hamiltonbeach.com/rice-cookers-and-food-steamers-digital-two-tier-food-steamer-37537.html#careguides
Mar 04, 2014 | Hamilton Beach 2-Tier Digital Steamer...
The plastic plate that came with my rice cooker, what is it, I lost my manual
What is the actual model number? HB makes several and none of the current or listed ones are 37531.
37541 is a current model, also none are "10 Cup" and the "plate" or tray, is for steaming vegetables.
http://www.hamiltonbeach.com/products/rice-cookers-amp-food-steamers-digital-simplicity-rice-cooker-and-steamer-37541.html
Sep 28, 2012 | Hamilton Beach 37531 10-Cup Rice Cooker
Can't find my manual
Seems they don't list your model but this is also the only one they do list and it is a 20 cup. Should give you enough info to care for yours and if you need a part this is also the site for that.http://www.hamiltonbeach.com/use-and-care/use-and-care.php
What is the rice to water ratio for cooking rice in the rice cooker?
Here's a simple one page guide for cooking rice in a rice cooker. It will tell you how much water to add depending on the type of rice you're cooking - How to cook rice in a rice cooker
Sep 17, 2011 | Hitachi RD5086P 8.3-Cup Rice Cooker
Info needed on rice cooker Bravett model MC665H, how rice can go into pot, what type of rice, and how long to cook
A cup of rice is equivalent to two person, depends how a person consumes the rice.
First wash the rice by rinsing it two times( using the pot itself ) with fresh water, add water till it cover the whole rice, amount of water should not exceed the level of your first line mid finger. After that put it in your rice cooker and switch it on. Rice cooker cooks it automatically.
White rice does not need extra time to cook.
Brown or any colored rice should be left or soaked for 10 to 15 minutes before cooking it ( because it is a bit hard ).
Hope that helps you out.
Thanks for using FixYa!
Jul 07, 2011 | Bravetti Kitchen Appliances - Others
Kitchen Appliances - Others Logo
51 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Marvin
Marvin
Vincent G
Vincent G
Harjeet s. bola
Harjeet s. bola
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
