Cars & Trucks Logo
w
william talbott Posted on Apr 06, 2017
How do you take the back off of a zebco 33 rhino reel
Its a newer style
2answers
2004f150 truck the newer body style when headlights are off I have no brake lights
So you're saying with your headlights off when you hit the brake pedal your brake lights don't work but when your headlight are on they do work? If that's the case sounds like your rear running lights and brake lights have tied themselves together on the same circuit
I have a taotao rhino and it jumped timing. I am trying to figure out how to put it back into the right time. the rhino doesnt have a timing chain so how do i set timing.
Get a Chilton repair manual they have a section on how to set timing. But you may be in trouble if it has a interference engine. A interference engine is where the piston and valve hit together.
How to fix a crack in a radiator
Depends where the crack is and if this is an aluminum with plastic tanks or the old style copper one. The newer style plastic tank ones are pretty much not repairable.
1helpful
Are the 1988 and 1990 chvy c15oo tail light assembly interchangable?
They also kept making the older style pick up in 2000, those light will fit. The newer style lights won't.
Fuel sensor does'nt register properly on the cluster, replacement of fuel level sensor procedure
the fuel sending unit is inside the fuel tank and is part of the fuel pump module, you either have to remove the fuel tank and then turn the fuel pump module locking ring to release the pump unit, and replace the in tire unit you may have to replace the wiring plug end most of the older pumps have been replaced by a newer style pump that uses a newer style plug, or you can remove the bed to get access to the fuel tank.....HAVE FUN
3helpful
Where does dvd go? we have the screens on rear of front seats
The old style sytem has the DVD player in the rear of the center console, the newer style has individual players in each screen. There is a small tab at the bottom of the screen, push it up and pull out, the bottom of the screen will tilt out and you insert the DVD up into the back of the screen.
I have a newer jeep wrangler early 2000,s how are the rear axle held in to the differential carrier?? im trying to repair a rear axle seal
There are two styles, typically. If you do not find a bearing flange and 4 (usually) bolts at the area of the backing plate, you may have a "C" clip style. To release the c style, you remove the pin for the idler spider gears and then push the axle in, then you can get the clip out, and pull the axle.
Doc
What should the fly-wheel bolts be torqued to on a 1996, Dodge Dakota, 2.5 liter?
55 FT LB if it is the older style OHC (Overhead Cam) motor
70 FT LB if it is the newer style OHV (Overhead Valve) motor
97 F-250 Transfer case shifter linkage broken!
97 f250 is it light duty - newer body style or heavy duty old body style??.. IF its older try 93-97 if its newer try-97-00
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
