Question about Nokia Cell Phones
My Nokia will not charge or boot up why? - Nokia Cell Phones
Posted by Shelley Kiehl on
Computer Repairing
  • Nokia Master
  • 14,641 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Posted on Jul 09, 2017
Complain
First Option:
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 15, 2012 | Nokia Lumia 800
Nokia6120c keypad 100% not working after a routine battery charge
brocken the keypad ic print of nokia 6120c
Aug 27, 2009 | Nokia 6120
Unlock my nokia6288
U get the unlocking code from http://www.mobileunlocksolutions.com/nokia-6288/rs1wp9/ . It provides the unlocking service for your mobile.
Aug 07, 2009 | Nokia 6288 Cellular Phone
Not booting
Charge it for an hour and then try to boot it
Jul 24, 2009 | Nokia 7210
Phone is not opening
Either your battery is shorted (diagnosed with an incurable disease) or your charging port is damaged. Examine the port of your charger and determine if looks in the same condition as it has always been.
Best way to diagnose your Nokia 3230 is to try a new battery. If the new battery will boot up the phone and charge the device, then you just needed a new battery. If the new battery only works to boot up the handset, but still fails to charge then your charging port is damaged or failed.
Thanks.
Mar 24, 2009 | Nokia 3230 Cellular Phone
Nokia 3230 boot failure or cannot star-up
Do a Full phone formatting following steps below:
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
  1. Green dial key,
  2. * Star key,
  3. no. 3 key on keypad
and then press the power on/off to switch on the phone.
Do not let go the 3 'press and hold' keys until you see a the word 'formatting' is displayed on the screen
Aug 05, 2008 | Nokia 3230
Nokia 6300 does not boot up when started
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Mar 26, 2008 | Nokia 6300 Cellular Phone
Nokia 9500 doesnot boot
hi for this problem == plz check this out www.nokiausa.com/support/phones hope you can get your cell back as it was! GOOD LUCK
Apr 28, 2007 | Nokia 9500 Communicator
Cell Phones Logo
95 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
