Question about Zebco Sport & Outdoor - Others
Where can I find any parts for a zebco 33 micro reel
Posted by james on
ray gallant
    Top Expert:
  • Zebco Master
  • 68,638 Answers
Http://www.zebco.com/ Zebco Fishing
Posted on Apr 05, 2017
How do I remove the front cover from the zebco 33 reel???
Turn the screw a 1/4 turn, then twist the front line cover left to remove it. It may be stuck but this is how you do it. It will move about an 1/8", then pull it straight off.
Oct 31, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
Looking for a zebco 33 reel parts book
Easy one
Got to the website. And type in the model number. there are different model 33 diagrams so make sure you have the correct one for your reel My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Jul 30, 2014 | Zebco Omega Spincast Reel
Zebco manuals
That would depend on the rod, but usually either the front part of the hand grip can be unscrewed, or there is a screw under the rod that will loosen it.
Jul 26, 2014 | Zebco Spincast 33 Rod and Reel Combo
Sport & Outdoor - Others Logo
319 people viewed this question
Top Zebco Sport & Outdoor - Others Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Zebco Sport and Outdoor - Other Expert? Answer questions, earn points and help others
