Question about JVC Computers & Internet
My jvc smart tv wont connect to wireless wifi just keeps saying disabled when I try 2 connect it worked for a while but stopped when I changed from sky broadband to Vodafone??
Posted by Kelly Boyd on
Larry Ng
  • JVC Master
  • 5,969 Answers
You need to learn wifi has credentials.
SSID name.
wpa1/2
and pass phrase.
learn to learn what the are or learn how to change them in the wifi router, if you own it, if you don't own the router learn that only the ISP can tell you this.
no country stated
no ISP stated.
no modem and or router stated
no stated owner ship of above HW.
Posted on Sep 15, 2019
5 Related Answers
Anonymous
  • 287 Answers
SOURCE: edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Posted on Jul 06, 2008
Anonymous
  • 68 Answers
SOURCE: PS3 keeps losing internet connection
Have your ISP check the refresh on there end (Suddenlink had mine set a 4 minutes instead of 24 hours)
Posted on Feb 05, 2009
Anonymous
  • 40 Answers
SOURCE: Not able to connect to internet, using wireless router (SKy),
One of the things that I have seen that might fix this problem is running a program called winsock fix. What this does it reset/rebuild your network config on your laptop. You will need to download this program from the other computer and then take it to the laptop via thumbdrive/cd. Here is the link. Hope it helps.
http://www.snapfiles.com/get/winsockxpfix.html
Posted on Apr 10, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Posted on Dec 26, 2009
Anonymous
SOURCE: My ipod touch wont connect to my wireless sky
i do and it enter the corect one but it comes up "unable to connect to this nework" my mums or sisters cazn connec either and its geting fustraing, can anyone help?
Posted on Dec 29, 2009
My tv will not connect to my WiFi
TRY the WPS button on the router, considering you have a wireless router. Write down the Key code listed on the WiFi Router as it may need to be used to connect your TV with the WiFi system. If your TV is NOT a Smart TV, you will need a USB WiFi receiver to attach to the TV. New Smart TVs have a built in receiver.
Jan 11, 2018 | Computers & Internet
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Dec 09, 2015 | Televison & Video
Why doesn't it connect to wifi anymore?
If reentering the password does not do the trick then the wi fi circuits of your "smart" tv have deserted you. A power failure will sometimes result in this and you have to re enter the password for it to reconnect.
Aug 26, 2015 | RCA Televison & Video
My jvc smart tv is displaying wifi dongle detected and is not connecting to my Internet and it keep showing on the TV is quite frustrating thanks
You can stop the display about the issue via ''settings''. To actually connect to the internet you need to enter your wifi security code. It should ask you for it, but it may only ask for it if you try to connect via the ''settings'' menu.
Dec 31, 2014 | Televison & Video
Need to change wifi passphrase to all numbers or all letters smart tv doesn't recognize letters and numbers
you can auth your tv to use wi-fi without password via mac from wify setup when detected.
disable passphrase from router and connect tv, auth tv and pus back passphrase and it should work, if not, change security type of router to another, WPA/WPA2 where it would let you enter any password you like.
Feb 26, 2014 | Computers & Internet
My wifi keep saying disconnected this phone is not on I just let my son use the phone to download apps I reseted everything because it was not working right yesterday and now i can't get the wifi back
try this solution...
1. select "airplane mode" to disable all wireless connection then turn off your phone.
2. turn on your phone then disable "airplane mode"
3. turn on your wifi now.
Mar 05, 2013 | Cell Phones
Wont connect to wireless internetthe laptop seems to be detecting the signal but it wont connect. just says connection failed.
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 01, 2009 | Computers & Internet
Computers & Internet Logo
2,277 people viewed this question
Top JVC Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Jim Pattison
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
