Question about Bosch Audio Players & Recorders
Hi, I have a Bosch built-in oven, model HBG23B4.1Y. About a week ago I tried to change the time on the display, and realized it did not respond to any button I pushed.
The oven still works, the clock on the display panel still shows and is keeping accurate time except for being an hour off since daylight savings time, and the lock isn't engaged. But no matter what button I press or how many times, it does not work. Any ideas? Thanks!
Posted by Mor A on
5 Related Answers
Anonymous
SOURCE: Clock working, but not displaying time
They say to hold the button for 14 seconds or til it beeps, for it to stay on.
Posted on Aug 26, 2008
laneycath
  • 3 Answers
SOURCE: Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Posted on Dec 09, 2008
Anonymous
SOURCE: how do i change clock to daylight savings time
Press and hold the plus button under the word time on your remote.
Nancy
Posted on Mar 08, 2009
Anonymous
SOURCE: Panasonic KX-T7730 - changing time display
Following are the steps:-
PRESS: - PROGRAM (PITS PGM NO. APPEAR)
- *#1234
- 000
- Speaker (Date/Time will appear on the screen & blink
- Point directional sign to the desired position to change accordingly
Once finish with the above - Press "STORE" button
Then lift handset and replace
MT
Posted on Apr 07, 2009
Anonymous
SOURCE: chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Posted on Jul 11, 2009
Bosch built-in oven HBL8450UC/01 displaying error code 126
E-126 ERROR CODE ... received this morning due to some burned toast! After smoke cleared and the oven cooled down I continued to display the error. I decided to let it sit for a few hours and after reading that it would need to be reset by a technician ---- I cut all power to the oven and then back on. The oven reset itself allowing me to reset the time. All functions appear to be back as expected, so this could be an option to try if you receive this E-126 flashing error code saving a service call! Hope you are lucky!
Sep 16, 2017 • Bosch Ovens
1helpful
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 • Bosch Ovens
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Touch keys on Bosch built in over HBL33 not responding
Not sure about your model but I have a bosch hgs7152uc model. I found that removing two screws and the metal panel in rear of the stove (at top where display is) will provide access to the control panel. There are four screws holding the display circuit panel in place. Two of the screws were not tight which allowed the circuit panel to move backwards when pressed. Tightening all four screws made the display operational again. The screws had lock tight on them but apparently they came loose anyhow over time
58helpful
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 • Bosch Ovens
2answers
Whirlpool dishwasher is making a loud whine while running.
Have you found a solution to your whinning? Mine is doing the same thing. Started about two weeks ago.
2answers
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
Did you get my reply about the light on my Bosch range?
hi...i am sorry for this delayed reply..my connection got screwd..well coming to your problem..did you ever try cleaning your oven interiors with any sort of cleaner..if so, then there might me moisture in the sockets..this is a common problem faced by a lot of kitchen range owners. hope this helps..and if in the latter case, please do update me...and i shall be more than glad to help you
Thank you for using Fixya
Top Bosch Audio Players & Recorders Experts
ADMIN Canada
ADMIN Canada
Harrie
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
