Question about The Toys
I'm looking for the instructions for my 1989 game also and pegs also put them up now can't find them
Posted by Terry thomas on
Mister Danger
  • The Master
  • 5,631 Answers
Specify please, what 1989 game?
Posted on Apr 05, 2017
We have the original games but some of the pegs have broken is there any way we can just get the plastic pegs
It depends on the age of the game. Firstly, try contacting the manufacturer's customer support department. Secondly, try looking in charity shops for games which might yield suitable pegs.
Sep 02, 2015 | Video Game Consoles & Games
Bought the electronic battleship , open it up , and there is more red pegs then the blue pegs .How many blue pegs suppose to be in the game?
I have the Hasbro Electronic Battleship Game. It includes 10 plastic ships, 84 red "hit" pegs and 168 white "miss" pegs! What make game have you bought? There will be more miss pegs than hits!
Dec 26, 2014 | Toys
I need game rules for 1978 Milton Bradley "Knock Out" game
So. I played this game years ago, and just pulled it out of my moms closet of games. Anyway, its similar to Othello, if you've ever played that. Start with putting pegs into the inner circle/hexagon, with every other peg facing opposite directions. Then the first player puts one of his/her pegs into the game, trapping their opponent's peg between theirs, and then pushing out the trapped peg and replacing it with their own. Once the board is full, the player with most pegs in it, wins. You can only push out pegs that are between the one you play and existing pegs from previous play.
Dec 12, 2014 | Milton Bradley Toys
I need set up instructions for electronic battleship.
You will need a phillips head screwdriver and 3 AA batteries. Flip the board over and locate the battery panel. Take out the screw and remove the panel. Insert the batteries in the alignment specified. Replace the panel and screw. Test it by pressing the "on" button. It should say "remote terminal activated, input number of players." Put the stickers on. The "player one" sticker goes on the side with the on switch. Remove the plastic pieces from the molds and divide them evenly between players. Each player should have five ships, 100 white pegs, 50 red pegs, 25 blue pegs, one red plane and one blue plane. Place pegs in appropriate compartments. The blue pegs and planes are only used in "advanced missions." Player One turns on the game and selects the game mode and how many players there are.
Aug 25, 2011 | Video Game Consoles & Games
I took the pegs off my son's mongoose outer liit freestyle bike (20") and now cannot figure out how to put them back on. I am not sure what to do with the silver washer?????
The silver washer will go between the frame of the bike and the peg. Then the nut for the wheel bolt will go into the peg and screw on from the inside of the peg. Unless they are solid pegs in which case you will put the washer on first still and then screw the peg on as if it were the nut itself.
Aug 20, 2011 | Mongoose 20-Inch Gravity Games BMX...
I bought Master mind for kids game, made by pressman. It did not come w/ any instructions. I need rules for the game to play the game.
The two players decide in advance how many games they will play, which must be an even number. One player becomes the codemaker, the other the codebreaker. The codemaker chooses a pattern of four code pegs. Duplicates are allowed, so the player could even choose four code pegs of the same color. The chosen pattern is placed in the four holes covered by the shield, visible to the codemaker but not to the codebreaker.
The codebreaker tries to guess the pattern, in both order and color, within twelve (or ten, or eight) turns. Each guess is made by placing a row of code pegs on the decoding board. Once placed, the codemaker provides feedback by placing from zero to four key pegs in the small holes of the row with the guess. A colored (often black) key peg is placed for each code peg from the guess which is correct in both color and position. A white peg indicates the existence of a correct color peg placed in the wrong position.
If there are duplicate colours in the guess, they cannot all be awarded a key peg unless they correspond to the same number of duplicate colours in the hidden code. For example, if the hidden code is white-white-black-black and the player guesses white-white-white-black, the codemaker will award two colored pegs for the two correct whites, nothing for the third white as there is not a third white in the code, and a colored peg for the black. No indication is given of the fact that the code also includes a second black.
Once feedback is provided, another guess is made; guesses and feedback continue to alternate until either the codebreaker guesses correctly, or twelve (or ten, or eight) incorrect guesses are made.
The codemaker gets one point for each guess a codebreaker makes. An extra point is earned by the codemaker if the codebreaker doesn't guess the pattern exactly in the last guess. (An alternative is to score based on the number of colored key pegs placed.) The winner is the one who has the least points after the agreed-upon number of games are played.
Jul 19, 2011 | Video Game Consoles & Games
How to install the peg perego car seat adapter on
You have to put the big bar through the wholes in the side attachments first before attaching the spring loaded bar. The big bar should be facing toward the front of the stroller.
Once the bars are all attached, the to clicky slots on the Peg should click into the small cross bar and the spring loaded bar. The big slot on near the back of the Peg should rest on the big bar.
Mar 05, 2010 | Baby Jogger City Series Single Stroller
Re: professor laytons seven squares
Not my brilliance I'm afraid, but found the answer on another website, have copied in below - it does work!
It is very complicated to explain but i'll try as best as I can. 1- First make a small square in the top left corner.(This is the only one that isn't at 45 degrees)
2- Next go to the far bottom left corner and make a small 45 degree (lop sided) square leaving only one peg in the middle.
3- Copy the same thing as you did for the 2nd square but this time in the far top right corner.
4- Use the peg that is in the centre of the square in the bottom left corner(2) and draw a line to the peg on the far right at the very bottom. Then draw a line to the middle peg on the far right. Then draw a line to the peg that is on the 2nd row from the top and 3 columns in from the left. Then complete the square connecting up the other side.
5- Start from the peg that is on the very far right that is free and connect it to the peg that is free at the very bottom. Then connect that to the peg that is free on the far left. Then connect it to the peg at the very top (out of the 2 that are free) on the right. Then complete the square.
6- At the very top start at the free peg and connect it to the free peg on the right that is in the centre of the small 45 degree square. Then connect this to the free peg in the centre of 4 other free pegs. Then connect that to the free peg that is furthest to the left and then complete that square.
7- As there are only 4 pegs left this should be easy to see a small 45 degree square. Hope this helps and didn't confuse you too much.
Nov 24, 2008 | Nintendo Professor Layton & the Curious...
Peg perego john deere gator 4X2
It is definately the gearbox. You cant find them too often but you will be able to bring it to a service station that is recommended by peg perego in your area. You can also look on ebay for new motors/gears and put them on yourself. Fairly easy.
Nov 10, 2008 | Peg Perego Vespa Scooter
Toys Logo
42 people viewed this question
Top The Toys Experts
Marvin
Marvin
Paul Carew
Are you a The Toy Expert? Answer questions, earn points and help others
