SOURCE: Display reads U60 Cooling Fan - oven won't heat
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
SOURCE: whirlpool wall oven error code
f3 generally relates to faulty oven sensor. thin rod in upper left hand corner of oven cavity held in by 2 screwa, easy enough to replace,
SOURCE: whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
