Question about Binatone Lands Phones
I have a Binatone 1910 twin but no dail tone when connect to NBN cable
Posted by shukhuanlim on
5 Related Answers
Chintu-KPV
Chintu-KPV
  • 202 Answers
SOURCE: home phone giving a high pitched dial tone .
This normally happens when the exchange junction box nearby has some problem... do call the line man to clear the problem
Posted on Feb 21, 2008
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: Panasonic Toughbook 51 modem error no dail tone
System restores do not erase any data or files that you have created and to get to it is from start>control panel>performance and maintenance>system restore
It saves all documents and files and the restore is completely reversible if it needs to be reversed
This is probably the easiest option to try especially since everything seems to be running fine.
you can also try first going into Hyperterm and typing ATZ and pressing "enter" which should reset the modem.
Posted on May 20, 2008
Anonymous
SOURCE: TC1200 TONES/PULSES
******** man even i know to see the manual.
Posted on Nov 01, 2008
ohjustwork
Oh Just Work
  • 50 Answers
SOURCE: my binatone 2136 has no
Make sure you are using the line cord supplied with the telephone. If you are and have broadband try without filter. If the display says "searching", "out of range" or "register" follow the instructions for handset registration.
Posted on Feb 25, 2011
Ishola Olayemi
  • 1196 Answers
SOURCE: binatone lifestyle 1910 is not
I will advice you try rese
t your phone with this code *# 7780#, press the code on your phone and send, this will help reset the phone.
Posted on Sep 16, 2011
Please help I can't ring out on my phone
Check for dialing tone by pressing 'Talk On' phone button.
If no tone, check cord at base station and the phone socket is correctly plugged in at both ends using the original cord supplied.
If still no dial tone, check the phone at another phone connection to establish if either the phone or the line is faulty. Address for
Binatone support at this link: http://binatoneglobal.com/support/
Jun 28, 2015 | Binatone Lifestyle 1910 Twin Cordless...
How do I extend the ringtone time of incoming calls on binatone lifestyle 1910
Most of the newer phones have a feature that quiets the ringtone when you touch the phone or move it. You can deactivate this feature in the settings menu. I hopes this helps you..
Nov 25, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Why when I phone some one I can hear them but they cant heat me
You may have accidentally pressed the Mute button. Undo as below
Mute a Call:
You can talk to someone nearby without letting the caller hear you during a call. During a call: Press <C> t o mute the microphone and "MUTED" will display on the LCD.
Your caller cannot hear you. Press <C> again to unmute the microphone.
Nov 19, 2014 | Binatone Lifestyle 1910 Twin Cordless...
How do I increase the external ringing volume on a
Adjust Volume
There are 5 levels (VOLUME 1 to VOLUME 5) to choose from for the earpiece or speakerphone volume
During a call: Press <up/down> to select volume 1-5.
The current setting is displayed. When you end the call, the setting will remain at the last selected level.
Sep 21, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
Mar 24, 2014 | Binatone Lifestyle 1910 Twin Cordless...
When I answer I can hear the person but they can't hear me
Ive got exact same problem and same phone! I hope there's a simple answer as my provider said I need to check its defo not the phone as if I call them out to check the line and it's actually the phone I get charged 99 pounds!! Eeek!
Sep 29, 2013 | Binatone Lifestyle 1910 Twin Cordless...
My binatone 2136 has no dailing tone and dont ring and brand new
Feb 12, 2011 | Cell Phones
THE PHONE SAYS LINE IN USE
Check to see that you have dial tone from the phone company by using a standard non cordless phone. if you have dial tone then check the cordless phone and make sure you plug into the correct port and ensure that you have the power plugged into the wall. Also, use the same cord from the standard phone that is connected from the phone to the wall to ensure that your line cord is not bad.
May 29, 2009 | Panasonic KX-TG5672 Twin Cordless Phone
Lands Phones Logo
42 people viewed this question
Top Binatone Lands Phones Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
