Question about Samsung Audio Players & Recorders
Samsung home-theater model no# HT-E330K, power supply ICA 801, qa 801 completely burnt can't see the value of the IC and transistor. Pls help with the value of the resistor
Posted by medscon on
Anu Sri
    New Friend:
I WANT HT-F450BK ICA801
Samsung home-theater model no# HT-E330K, power sup - 1_4_2018_5_04_56_am.jpg
Posted on Jan 04, 2018
5 Related Answers
petraman7
Scott Frye
  • 1175 Answers
SOURCE: monitor diagram
www.servicing-manuals.com
Posted on Feb 02, 2008
francis rivero
  • 958 Answers
SOURCE: Need instructions to install replacement fan/motor for Home Theater
open your unit. locate the fan, remove the old one, install the new one. connect black to black and red to red on the wires.
tnx 4 using fixya,
drcool
Posted on Oct 24, 2008
Anonymous
  • 144 Answers
SOURCE: HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Posted on Jan 18, 2009
ABRsvcs
  • 4234 Answers
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
Posted on Jan 21, 2009
Anonymous
  • 3 Answers
SOURCE: Burnt out resistor
I have put a 1k 1/4w resistor in place and all is working
Posted on Jan 23, 2010
My Samsung HT-E330K keeps shutting down when the volume goes above 15, how can i fix this?
You may have a shorted speaker voice coil, the voice coil shorts above the volume setting you mentioned, try unplugging the speakers one at a time and see if the problem stops.
Oct 25, 2016 | Samsung Audio Players & Recorders
My home teather is samsung ht-e330k when i put on the power it says prot then it torns off how can i fix it??
It means "protect". It's possible that a speaker cable is touching or shorted out somehow. Check all wires and speakers for faults. Then try again. If it doesn't correct itself, it might have an internal short in the main amp.
Sep 03, 2016 | Samsung Audio Players & Recorders
Model HT-E330K ..what is the number of transistor in part # QA801
Find the transistor on the board and look very closely at the markings (values) on the part in question. Use google for data sheets. Or, better yet, find a copy the schematic.
Feb 27, 2016 | Audio Players & Recorders
Samsung home-theater model no# HT-E330K, power supply resistor RA805 completely burnt can't see the value of the resistor. Pls help with the value of the resistor
This may sound like a lazy answer but without a schematic, its going to be tough. Perhaps you know someone...or maybe there is someone here who has the same unit who wouldn't mind opening it up to get the value. Good luck.
Oct 08, 2013 | Audio Players & Recorders
Unlock samsung HT E 330 K
Hi i am using samsung dvd HT-E330K..I cant watch few dvds on my dvd ..i need the code to unlock my dvd so i can view all the dvds
Feb 23, 2013 | Audio Players & Recorders
Turned on system. it shut off. tried to turn it on again the display screen lit up and went out now i get nothing.
If every segment on the display lit up it will need a display driver IC (pain in the a## to replace need to remove the display to get at it) and it will also need a transistor in the power supply.
Feb 10, 2010 | Samsung HT-Q70 Home Theater System System
Burnt out resistor
Sep 09, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
370 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
