SOURCE: sharp aquos lc-37d43u tv
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
SOURCE: the power light and OPC light flash but TV won't
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
SOURCE: My Sharp Aquos LC-52D64U shut off by itself, and
sounds like power supply/ohm supplies for repair in uk
SOURCE: no picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
SOURCE: 52 sharp aquos tv wont turn on. Hear click of tv
This tends to be the result of an electrolytic capacitor somewhere, either on the main board or the power supply board bursting due to overheating. In this case you can pull off the back paneling and review the boards over to make sure all the capacitors are in excellent condition. After identifying a bad capacitor you can buy one from an electronics store in the area or a reputable online source. To replace it this will require soldering. Look for a capacitor with the same uF, the voltage can be the same or higher. Make sure all the power is out of the system before servicing, also make sure to note capacitor polarity observing the negative indicator line on the side. If your not sure this can be done at home I would recommend taking it in to a servicing shop. If you do not know what a capacitor looks like do a google image seatch for both examples of a good and bad copacitor. I honestly hope it's something much simpler, I hope this helped and good luck.
