Question about Canon Rebel XT / EOS 350D Digital Camera
I know this is probably too easy for you....
But somehow there is a significant delay before the picture is taken after the button is pressed. I have a two year old Canon Rebel XT and I'm very amateur. The delay is killing any action shots. What did I do to create this>
Posted by bettylouie on
Anonymous
  • 22 Answers
Hi
look a the settings currently on your camera
turn the knob to full auto and then go to the menu and do a full reset of the unit (see page 100 of manual)
then progressively re-add your custom settings
another option is that you have the shutter set to timer mode
change to 1/multi to repair
D
Posted on Nov 21, 2007
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
Setting the timer
Press the 4-way switch downwards to cycle through the selftimer modes: First press shows the selftimer symbol, which means 10 secs delay, next press shows selftimer2 symbol, which gives 2 secs delay. When delay is set, press the shutter button to take the picture. The selftimer lamp will blink untill the picture is taken.
Jul 08, 2010 | Fuji FinePix F10 Digital Camera
How do i turn on the auto timer?
Hi, Follow these steps:
1. In any Still mode, tap Settings to open the Settings panel.
2. Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
3. Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures
Apr 13, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
How do you set the self timer on the kodak 10.3 mega pixels
1 In any Still mode, press the button repeatedly to choose: 10 seconds?A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds?A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot?The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later. 2 Compose the scene. 3 Press the Shutter button halfway, then completely down.
Nov 19, 2009 | Kodak EASYSHARE M1063 Digital Camera
Delay between pressing button and actual photo taken
hi
there is a lot to takin good pictures but its easy too
now when are you facing this prob during low light situations or regularly
if it is during low light then pitching up ur ISO settings say from some 80 or 100 to atleast 400 or 800 should do the trick but beware of a lil picture noise,
also u can turn on the continuous focus(CF) setting
also when you are taking a picture try to focus on the subject by pressing and holding the shutter button only halfway then once you r safisfied with the way it looks press it down all the way to take the picture this works for all photos whether in day light or during low light
if u have any further questions u can contact me on [email protected]
cheers
pls rate if this was any help
Jul 03, 2009 | Panasonic Lumix DMC-FZ30 Digital Camera
Timer?
hi... try this method
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
tripod).
The camera takes the picture/pictures after the delay....
thank u
May 24, 2009 | Polaroid i830 Digital Camera
Using self timer on my digital camera
panel.
tripod).
Apr 29, 2009 | Kodak EasyShare V1073 Digital Camera
Delayed preview image
Sounds like you accidentally pressed the DISP button on the back (it manually turns the LCD screen on and off to save batteries). Turn the camera on and press the DISP button once. Hopefully that should fix it.
Mar 24, 2008 | Canon PowerShot A550 Digital Camera
Taking a photo of the family, delaying the camera until I can get into the shot.
Sure, follow these steps...
  • Set everyone in an even composition, close together, maybe some standing, some sitting, whatever strikes you as a good picture.
  • Put the camera on a tripod or other tall article
  • Press the Mountain/Macro/Timer button until the (clock/timer) icon is displayed on the viewer. The button to press is just above the MF (Manual Focus letters)
  • Press the shutter button all the way down to activate the timer.
    • Press once for ten-second delay
    • Press twice for three-second delay
    • Press a third time to stop the timer
  • Jump into the shot! =)
The lamp next to the lens will start to blink and continue until one second before the picture is taken. The lamp will then stay solid during the last second to warn about the picture being taken.
Please rate FixYa!, ThankYa!
Dec 15, 2007 | Nikon Coolpix 4500 Digital Camera
Miss all the action shots with this camera
The longest part of the shutter delay is caused by the autofocus mechanism. Most cameras will let you press the button half-way down and wait until the autofocus is locked. Then wait for the action to occur. When you press the button the remaining distance, there will be a shutter delay of about 0.2 seconds before the picture is taken. Using that technique will let you capture action shots. There is no way to improve shutter delay on any particular camera. The newer digital cameras are showing improvement in this area. Some are achieving autofocus lock in 0.4 seconds and shutter delay of an additional 0.1 seconds.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
halotheracer
halotheracer
Are you a Canon Camera Expert? Answer questions, earn points and help others
