What does quantitative observation mean - Computers & Internet
Posted by Tina Musumeci on
Rocy Cat
  • 3 Answers
Do you want to know about quantitative research. As you know, quantitative research is a summarised way to represent the whole information. You can also visit ontd to know more about different topic.
Posted on Oct 14, 2021
Bobby Lewis
    Novelist:
  • 165 Answers
Quantitative observation, also called quantitative data, includes information that includes numbers, measurements, and statistics. Quantitative data serves as a tool to measure data in many areas, including algebra in mathematics. Quantitative data complements the use of qualitative data, which uses descriptions, adjectives, and linguistic elements to describe objects and images.
Posted on Apr 02, 2017
What is the purpose of nbt test for universities
The NBTs assess the ability to combine aspects of prior learning in competency areas - Academic Literacy (AL), Quantitative Literacy (QL) and Mathematics (MAT) - that directly impact on success of first year university students.
1helpful
DAIHATSU FEROZAdistributor assembly ,complete/ please can anyone send me please?
Do you mean car lubrication oil dispenser of daihatsu ayla?
For automobiles, many internal parts need lubricating oil for lubrication. The lubricating oil is distributed through the lubricating oil distributor, because the general oil path is equipped with a lubricator, and the lubricating oil distributor is installed on the oiler. Because the oiler usually has only one oil outlet, only through the distributor can the lubricating oil be quantitatively distributed from the oil outlet to lubricate the parts.
2answers
Example of quantitive data
the testing dat shows water boils at 212
the testing showed chocolate melts between 95 degrees and 140 degrees
qualitative would be.
Because I am a scientist I think that group of ingredients will have a melting point of 175
2helpful
What does hypothesis mean
A hypothesis is a proposed theory that could explain a set of observations or circumstances. It usually requires experiments to test it before it becomes an accepted theory. Testing often takes the form of "the hypothesis explains all of the observations, but if it is true, then it suggests one should observe x when y happens.
What is the meaning of the word observe
In reference to vehicle care maintenance, "observe" means looking for something that was not there before. For example, as you pull into a parking space, you "observe" the pavement was dry; but when you return later, you now "observe" there's fluid beneath the engine area. Conclusion -- a cracked hose connection or brittle gasket sealant needs to be replaced. Another example is when you "observe" a condition that was not present before. For example, you're driving along and suddenly hear a noise that was not there before. Conclusion -- a nut or bolt connection had come loose from both, engine vibration and the vibration as the vehicle travels along rough uneven pavement.
I have a nikon n65 with a broken battery door what do you recommend
Contact Kelly at Spartan Photo Center 864-583-6835. Those parts are still available in limited quantites and they had some last timI checked. You can remove a few screws and replace the door yourself if you have some basic mechanical ability.
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70...
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
We cant figure out how to get our Konica 7065 to copy and staple with the page positioned and scaled correctly.
put the at lest 2 original documents on the (adf) then put the quantite then go to output on the screen chosee the position set what you wont to use . and then press ok .
Computers & Internet Logo
Ekse
