Question about Alphasonik Car Audio & Video
Where can i buy a refoam for alphasonik mayhem 15?
Posted by Robert Kirby on
1 Related Answer
micmor100
Morne Olivier
  • 257 Answers
SOURCE: which speker box should i use for alphasonik
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches
Posted on Jun 08, 2010
Trying to 1ohm my sub for a 2 channel brideable amp
you can only do that if your sub has a switch on it otherwise just hook it up and pound it
Sep 08, 2011 | Alphasonik Mayhem PSW912 Car Subwoofer
I would like to know if I need a special plug to bridge the amp and were can I buy the owner manual
I just got an alphasonik pma800da today, it came with the cord you are talking about. Looks like a phone cord, its to hook up 2 of these amps together. I also have the book to the amp
Dec 26, 2010 | Alphasonik PMA800DA Car Audio Amplifier
Recall
they can be easily blown/burned out
Jun 03, 2010 | Alphasonik Mayhem PSW912 Car Subwoofer
Which speker box should i use for alphasonik
Mar 15, 2010 | Alphasonik Mayhem PSW912 Car Subwoofer
The 6.5 foam ring
This is a very common problem and I don't know why companies still use foam.
The ring is called the "surround" and the problem is known as "surround rot".
There are 3 fixes.
Replace the entire driver. (most expensive)
Recone the driver (tear out the old cone + surround + spider and glue in a new one using the old basket).
Refoam the surround. (replace just the foam surround).
I know of one location in my hometown (Ottawa Ontario, that does re-foaming and people that do this are few and far between).
If you can find someone to refoam it go that route, failing that do a recone. A recone will last just as long as a new driver.
Hope this helps!
Cheers,
Jan 24, 2010 | Audio Players & Recorders
How to refoam bose 901 IV
There are many kits available on eBay, with instructions.
Search "bose 901 refoam", check the 'include description' box.
Dec 04, 2009 | Bose 901 VI Main / Stereo Speaker
Which is the size of the box just for one PSW912 to mount
I used to compete with these subs, and found that for street beat 2.7 cu ft ported tuned at 38 hz was the best for this sub.
If using for max SPL your tuning will be much higher, like around 55 hz. But that all depends on the vehicle.
Aug 09, 2009 | Alphasonik Mayhem PSW912 Car Subwoofer
Alphasonik amp is getting power but no power to subs
either your rca inputs are bad or your mosfets are bad
Jul 05, 2009 | Alphasonik PMA1000D Car Audio Amplifier
THE WOOFER RATTLES REALLY BAD WHEN ANY MUSIC OR VOCAL IS RUN THROUGH IT, WE HAD THIS PROBLEM A FEW YEARS AGO AND REPLACED THE WOOFERS IN THE FRONT OF HOUSE MAIN PA SYSTEM, THE VOICE COIL WAS BAD.
you can have the woofer reconed, refoamed or replaced. if the voice coil is bad then you can only refoam or replace. if the problem is that the poly foam surround has dry rotted, then it can be refoamed or you can purchase a DIY refoam kit. there are also many replacement woofer options.
[email protected].
Jun 10, 2009 | Soundcraft SP820 Main / Stereo Speaker
Car Audio & Video Logo
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
