SOURCE: Avanti Beverage Cooler BCA5105SG running very loud.
Inside the cooler is the evaporator fan usually right in the middle behind a cover. As it slows down you have less circulation and ice forms quicker and cooling is diminished. Sounds like it is going out.
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
