SOURCE: Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
SOURCE: I think I need to drain/flush our hot water heater
hi first making sure not to burn yoursel switch of heater and drain down down water from taps this may result in causing an air lock dont worry ! at the base of the heater you have the stat and element housing first withdraw the stat then the element alowing any remaining water to drain when fully drained turn on your water supply to flush out and clean replace element and stat using plummers sealent or tape hope this helps
SOURCE: water dripping out of drain line
The T & P valve is connected to the drain and it may be bad causing it to drip. You could try lifting the lever and then closing it back on it to see if it will seal. Also check the thermostat for heat setting, but than likely it is going bad.
It is a pressure relief valve and normally last about 5 years or more before they need to be replaced. The purpose of this valve is to protect heater from building up pressure and protecting the home, It releases water once the heater reachs beyond the limit of the valve can handle.
It is a standard 3/4" thread and can be removed with a pipe wrench. Just turn power, water off and drain water down to just below where the drain is.
Lowes or Home depot shoul dhave one just ask for a pressure relief vakve for a Hot Water Heater. prices range around $15.00.
Testimonial: "The response you forwarded to me was not the problemm. I simply had to drain tank down and replace plastic drain valve to a brass one. Plastic Drain Valves are prone to leaking"
