Question about Sony BRAVIA Televison & Video
My Sony Bravia screen was squirted with a water bottle.
Posted by Nyla Hawkins on
PLease help- When i pour water in water bottle of my Toyota lucida 94 reg-it pours straight out the bottom, any ideas why ?
What water bottle? If it is the windshield washer, then either the hose, pump, or bottle itself is cracked. Find out exactly where the water is coming out.
If some other bottle, answer the first question.
Thanks, Jim
Mar 08, 2011 | 1994 Toyota Previa
My Sony flat screen bravia hdtv 40" when i turn it
Your LCD TV needs repair,abnormal display caused by a faulty LCD Control board. Replace the control Board.
Nov 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We need our Sony 52W4100 Bravia screen replaced. What is the cost?
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
Part # 1-802-791-12, cost approx $2,251.54 + core
Parts reference: Andrews electronics, 800 289 0300.
May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Wher is the rear winscreen washer bottle on a ford
It should use the same tank as the front washer fluid
Sep 14, 2009 | 1996 Ford Bronco
Engine misfire and Service light on
Start the car take a squirt bottle of water and squirt the coil to see if it starts to miss again or see sparks jump.
Aug 01, 2009 | 2002 GMC Envoy
Replacing LCD TV screen
crack on the screan of 32 inch plasma
Mar 03, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Screen washers(front and rear) not working
Quick test since you can hear pumps running: Open hood. Look for a rubber hose going up from engine compartment to underside of hood. This should split somewhere if there are two washer jets on your hood, or else they go to your wipers and squirt directly off them, right? There will be a spot close to where this hose leaves the eng. comp. and joins with the hood that uses a splice connector. You can disconnect the hose here with some wiggling, and hit the squirters again to see if water is at least coming out of this primary hose. Yes? Good then the clog is at the jet end, or squirter end. Use a tiny piece of wire, like a bread tie without the insulation, and poke into the hole of the jet and try to clear out the dirt, or mineral deposit, dried soap scum, whatever. Now squirt again. Should start to clear out, or use compressed air and blow through jet. If your clog is not at the squirting end, follow the hose down to the little pump at the side/bottom of your juice bottle. GOod luck, and don't use too much additive, it clogs easier. Also don't use tap water if you get a lot of scale from hard water. THis will clog, too. Good Luck, TT
Feb 11, 2009 | Ford Focus Cars & Trucks
Televison & Video Logo
56 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
