Question about Simplex Locks & Locksmithing
SOURCE: how to change the combination of a Simplex pushbutton lock
Your screwed.
Posted on Mar 18, 2010
SOURCE: can a L1000 series simplex
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
under L1000/Specification/SimplexL1000 Catalogue PDF
Posted on Apr 10, 2011
SOURCE: I have a 5 button
I can't help you directly, but I will steer you to further information.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on May 13, 2011
Testimonial: "Thaks, I was able to download pdf and problem was solved.."
SOURCE: how do i change the
I'm not sure of your exact model, but I think you will find the information that you need listed on this grid chart:
You can cut & paste the link or type it into you browser's search bar.
Hover your mouse over the right-most column (Tips) for your model and you will pop up links for Changing the Code or Resetting the Code.
These are PDF files, requiring that you have Adobe Reader or equivalent installed on your computer in order to view them. If you're not able to view them install Adobe Reader from this link:
http://get.adobe.com/reader/
Posted on Jul 14, 2011
Apr 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Feb 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Feb 14, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Feb 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Jan 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Nov 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Jul 13, 2010 | Simplex Kaba Ilco Unican LP1000...
538 people viewed this question
