Whenever I try to select printer properties below my printer option in Word 2016, I get an error saying, "Microsoft Word has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." It then prompts me to close the program. I've tried this on multiple computers and copiers and it's doing the same thing on all of them.
SOURCE: yahoo messenger has stopped working
I have gotten this issue several times being a tech for the HP notebook division and I found a simple solution for it.
Right Click on the Yahoo! Messenger icon on the desktop and select properties.
Click on the Compatibility Mode tab
Check the box at the top to enable it and make sure the mode is Windows XP SP2.
Select ok.
Restart machine.
I hope this works for you all. =)
SOURCE: microsoft zune has stopped working
It's a glitch with Microsoft. All 30 gig units are affected. It's a leap year and the extra day threw the software. Let it discharge overnight and plug into your computer in the morning to load. Microsoft is supposed to have a fix. Thousands are affected.
SOURCE: a problem caused the program to close
Remove the program using ctrl/panel and remove programs and then reboot system. Now install program again. It should work now.
SOURCE: Acer Empowering Technology Framework Launcher
Start menu- >run
write MSCONFIG
Startup tab
Uncheck Acer eAP launch tool
Apply.. then ok and restart.
SOURCE: "Internet Explorer has has stopped working..."
After installing IE8 on vista I kept getting msg Internet Explorer has stopped working - continually looping thru this message.
Solution for me was.
End IE with task manager - needed to do a couple of times.
Then from control panel -> programs -> manage addons I disabled all add ons and then IE started OK. Then by process of elimination stated enabling add on until failed again.
In my case it was the skype addon that was causing IE to fail. Leaving it disabled has allowed IE8 to function.
