Question about Hotpoint Microwave Ovens
Hotpoint RVM1335BC001 microwave oven - Hotpoint Microwave Ovens
Posted by gle1 on
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Melted turntable support
Yes, that's part # WB06X10138 (coupler) and you can get it here.
You will need to remove the bottom cover of the microwave and remove the turntable motor to get the new coupler in.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
flatech
Michael McQuay
  • 111 Answers
SOURCE: How do you replace intermittent door switch on
Open the Micro door, and remove the air/Vent cover on the top if there is one, Usualy 2 screws on top or the middle of the cover.
Remove the screw holding the Controller board and then you will have access to the door switches 2-3 of them depending on Manif.
Also make sure you have the power unpluged befoe you do any of this.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Posted on Oct 27, 2009
Testimonial: "You haven't failed me yet. You guys are great!"
Rvm1335bc001
sounds like the control board, but most times the magnetron fails and if a fuse failed then it needs a capacitor too
Nov 27, 2013 | Hotpoint RVM1635 Microwave Oven
We have Hotpoint Model # RVM1535DM2WW microwave that all operations work except it stopped heating. Manufacture date is Jan 2010.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 16, 2011 | GE Hotpoint Over-the-Range Microwave
Hotpoint Microwave oven Model RVM1435WD will not heat up. It will start and the fan runs, but will not heat any food,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 | Hotpoint Microwave Ovens
Hotpoint model# rvm1435wh001 working fine but not heating the food
Basic Microwave Oven TroubleshootingTips
heatman101[]][\-==-
May 10, 2010 | Maytag MMC5000 Microwave Oven
How do you replace intermittent door switch on Hotpoint RVM1335BC001 microwave
Oct 27, 2009 | Hotpoint RVM1635 Microwave Oven
Microwave turntable does not turn
In microwave ovens, I have had the turn table motor unit become defective, or the power source to it has failed.
Jerry G.
May 15, 2009 | Hotpoint RVM1435 Microwave Oven
Jul 03, 2008 | Emerson MW8108P Microwave Oven
Powers on, rotates- but does not heat
Thanks for mentioning that growling sound, which is a classic clue to a bad mag, though not all bad ones make that sound. Sounds like someone growling into a coffee cup! *grin* For this job, the unit will probably have to be taken down from the wall mount. I recommend 2 people for that job. A spotter, if you will. When replacing the magnetron, it's very important to be sure the new one has the wire mesh "washer" (RF gasket) around the antenna which sticks out the top. If it's not on the new one, use the one from the old mag. Very important. Also, you should really discharge the high voltage capacitor. This case also illustrates an interesting thing about part prices: GE http://www.geappliances.com/shop/prts/ WB27X10017 $121.75 Appliance Parts Pros http://tinyurl.com/gv383 10QBP0230 $60.42 (check this one to be sure picture matches yours) A-1 http://a-1catalog.com/10qbp0230.html 10QBP0230 $54.00 Tritronics http://www.wehaveparts.com 10QBP0230 $42.85 I can advise you further concerning safety and disassembly if you need help: http://www.fixya.com/GetServiceUrl.aspx?advid=14&ctgid=153
Dec 14, 2006 | Hotpoint RVM1635 Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Ekse
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
