Question about Chime Home
How to fix emperor grand mother clock chimes hour chime one half hour
Posted by Edythe huisinga on
Lisa Lannom
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 32 Answers
Try to carefully remove the minute hand entirely from the clock then put it back in the "proper" place. for example, when it strikes at the six, remove the minute hand and put it back on pointing at the 12. Then re-set the time for half-past (or maybe quarter-till the hour by now! lol)
Posted on Apr 03, 2017
5 Related Answers
Anonymous
SOURCE: seiko mantle clock (switchable chimes)
See this site
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
Anonymous
  • 5 Answers
SOURCE: I have a Strausbourg chime mantel clock. It chime
each press of the red button will advance the chime count by one. Advance the chime count to match the face clock
Posted on Jun 05, 2010
Anonymous
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Posted on Nov 10, 2010
small6363
  • 18429 Answers
SOURCE: Elgin Anniversary clock chimes early
take the big hand off and move it back one square on the shaft
Posted on Nov 12, 2012
SOURCE: i have my mother's seth thomas mantle clock
If your clock has a small hole between 4 and 5 then you can turn off the quarter hours chimes using the small part of the key. If your clock does not have that small hole you can not turn off the quarte hor chimes.
Posted on Jan 31, 2013
Our clock chimes 3 hours ahead, if it is 7 o'clock, it chimes 10 times. we have tried all the fixes in the owners manual and nothing is working.
With our old clock when the chimes got off, we would advance the clock hands 3 hours while NOT allowing the clock to chime any of the hours or half-hours.
Jul 17, 2017 | Home
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 | Home
The clock chimes right on the hour and used to chime once on the half. Now it chimes the number on the half instead of once.Need just chime once on the half
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Feb 26, 2016 | Home
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
Sep 21, 2015 | Seiko Mantel Clock
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
How do I silence and turn on chimes on an emperor clock?
Not all Emperor clocks have a silent chime feature.
Main Page
Dec 07, 2014 | Home
My wm widdop clock chiming out of sequence
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Oct 21, 2014 | Home
Home Logo
2,427 people viewed this question
Top Chime Home Experts
Marvin
Marvin
Vernon Taylor
Fahr Quad
Are you a Chime Home Expert? Answer questions, earn points and help others
