SOURCE: itouch wi-fi connection problem
Try this one : http://wiredforgadgets.com/?p=743. It worked for me.
SOURCE: apple ipod itouch connection to wireless internet
It's since the touch doesn't officially support WPA PSK and only supports WPA2. What will work is WEP and although it is less secure very few people will bother cracking your network. If you continue to have problems with your secured connection try putting the hex key instead of the passphrase (you set hello as your password the hex would something like 0X34Hg65) it is usually displayed just beneath the password you set.
SOURCE: No Wi-Fi
Well since you jailbraked your iPhone you can not use wi-fi because jailbreak disables that future what you can do is restore your iPhone to factory settings.
Thank You,
Apple Care Technical Support
Stacy R.
SOURCE: iPhone 3G keeps saying 'bluetooth unavailable' and 'No Wi-Fi'
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I recently found an Apple iPhone 4 16GB in the
ha ha !!!!!,I don't think so.
First of all what the Apple iPhone was made for in the first place was not for you network provider to be tracking you where ever you go, it's for your own use alone. Network providers just gives you access to operate the phone by providing network for your access your Apple iPhone.
How does Wi-Fi work on a Apple iPhone ?
Apple's iPhone is a multimedia connectivity tool. As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media. To use the iPhone's WiFi feature just follow these steps.
Instructions on how to use Wi-Fi on your iPhone.........
Tap a network. If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks. Tap the network that you want to connect to in order to connect. If there is a password required a little lock icon appears. Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal. As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection. The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another. The more bars there are the better the signal.
Make connecting to WiFi automatic or manual. The iPhone is equipped to automatically search for available networks and connect you to one. If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu. Then select either the on or off option of the "Ask To Join Networks." Turning this option off requires that you find networks manually.
Forget a network. Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity. To forget a network so you don't get automatically connected choose the "WiFi" option on the menu. Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network. That all, Very easy to use too.
Hope that helps.
Thanks for using fixya.....
Testimonial: "Thats AWSOME! Thank you very much for the information and your assistance!"
