Question about Sony Radio Communications
The fork that connects my right ear piece to the headset broke, on my Sony mdr-rf970r. Can I get a replacement fork?
Posted by Steve Skolnicki on
5 Related Answers
Anonymous
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Posted on Nov 14, 2008
Anonymous
  • 7 Answers
SOURCE: sony mdr-rf970r does not work, there is a lost of
make sure your not using them anywhere where theres a lot of electrical equipment around, it sounds silly though their prone to interferance so take the base and place it away from any other equipment and see what happens, hope this helps :-)
Posted on Aug 04, 2009
Anonymous
  • 4 Answers
SOURCE: sony MDR-XB700 broken left ear
You could try to use a player with a stereo balance and adjust that, but in reality you need new headphones. Sonys have very comfortable and flexible cabling but the downside is that they wear out easily.
Posted on Mar 14, 2010
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: I'm looking where to buy
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=MDRRF970RK&sessionId=FLk3TTjKj9RC2AYaSnUQb_k
This is the link from sony style for accessories and online ordering for your headset. Hope this helps.
Posted on Oct 03, 2010
Anonymous
SOURCE: Can I replace the ear
Hey--it was reassuring to see that I'm not the only one with this question. Lots of places (Staples, Radio Shack) have the right size replacements, but it takes a little more digging to be sure you can find something more than what looks like doughnut-shaped packing material. B&H Photo Audio does, and here's a link: http://www.bhphotovideo.com/c/product/582208-REG/Pearstone_8091000_Replacement_Earpads_Pair.html
Posted on Jan 26, 2011
Are there replacement ear pads that will fit on my 2005 Sony headphones ?
There are lots of generic (Chinese) replacement ear pads for Sony on ebay or Amazon, you'll just have to take some measurements and try to match what's available. Check the diameter in centimeters, and the shape (round or oval). You may not find a specific listing for MDR-RF960RK but a lot are interchangeable.
2answers
I am looking for replacement earpads for Sony MDR V600 headphones. Will replacement pads for MDR 7506 fit the V600?
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
12helpful
I have Model MDR-RF970R and the battery is not holding a charge. Where can I get another battery? The # on the battery is BP-HP550-11/2.4v 550mAh. Thanks. Joe
Sony has some special case they put around the original 2 batteries to hold them together.
You don't need to buy special batteries. You can put regular AAA NiMH in.
To remove the compartment cover on the headsets make sure you hold down the pressure button on the left headphone to release the cover. Mine has the words "PUSH" on them.
With the cover removed you can then see the original BP-HP550 sony battery. Which you can remove and put 2 regular AAA batteries in.
6helpful
2answers
I'm looking where to buy sony mdr-rf970r ear pads
4helpful
Can I replace the ear cushions on a Sony MDR-V200 headset?
1helpful
Need replacement batteries for Headphones(Sony) MDR-RF970
You can use 2 AAA batteries. I just tried it on some similar headphones (MDR-RF970R).
1helpful
Replacement pads for sony headset MDRCD6
Hi Hifi-fans.
The MDR CD6 is still my favorite, since more than 35 years. My feeling was right, I would never find a better headset than this. This was the reason, time ago I bought a second set. You can imagine meanwhile I may have to replace the x-generation of ear-pads. The first ones I ordered for a lot of money at our Sony-HQ in Colone, Germany. Meanwhile I had found a better, more flexible solution. I had checked at our electronic storehouse, which headset from another manufacturer the pads are removable without damaging. I did select the Genius HS-04S ones for the PC and they are really cheap and you may use them without the pads. At the MDR CD6 the pads does not sit much strong, but this not really a lost.
All the years I did not use the second headset, the spare one. Nevetheless the ear-pads were damaged. The covering rubber was harded and broken like old plastik. Just some minutes ago I replaced the pads by the Genius ones.
So far, good luck and I am quite sure you may find the Genius in your country.
Radio Communications Logo
Top Sony Radio Communications Experts
 Grubhead
Grubhead
durantheman
Dennis
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
