There are 4 pins on the switch, which ones connect to the two wires? Hope you can help.
SOURCE: Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
SOURCE: Help with a Dismantled Osterizer Classic Blender
With the unit upside-down and the bottom off the wires on the right side of the switch go like this:
yellow on top
black on middle
red on the bottom
No wire connects to the 4th connection point (top left side).
R.
SOURCE: Connecting Leviton Decora light switch.
At the switch you have a feed wire coming in this brings in power which originates in the electric panel. You also have a feed or feeds goings out to other lts or switches, this you seem to have on the switch. instead of the closet switch loop.undo all the wires. find the only hot this is the one wire you can touch to the others and make different lts come on i reccomend getting a electric tester to do this. FInd the wire that goes to the closet lt. Once your sure put it to the side. wirenut all other wires together with the hot wire. this makes all other switches independantly hot. connect the hot to the switch and the closet lt to switch. I HOPE THIS MAKES SOME SENSE TO YOU . let me know if i can help
SOURCE: 1979 Toyota Hilux alternator wiring
always, counterclockwise starting with blue, then yellow, then red
SOURCE: Where does the extra white wire go from the MC42 electric motor
The red and black wires supply power to the motor to either turn it one way or the other. The white wire is neutral. The motor is dc; look at the nameplate data and it tells you the operating voltage. Black and white make the motor turn one way, power to the red and white and it goes the other way. (Black neg. Red pos.)
To install:
BROUGHAM
1. Disconnect electric-al connectors at blower motor,
compressor cycling switch, power
module and radio lead-in connections.
2. Remove righthand windshield washer nozzle.
3. Remove righthand secondary air inlet screen from plenum.
4. Partially remove rubber molding above plenum.
5. Remove remaining screws and the primary inlet screen.
6. Remove blower motor.
7. Remove two screws securing compressor cycling switch to
module and position
switch out of way.
8. Remove AC module cover attaching screws and the cover.
9. Disconnect heater hoses at heater core.
10. Remove screw and retainer holding heater core to frame
top.
11. With temperature door in max. hot position, reach
through temperature housing and
push lower forward comer of heater core away from housing,
then rotate core
parallel to housing.
12. Remove heater core.
13. Reverse procedure to install.
