SOURCE: 7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
SOURCE: How can I see a Microsoft Power Point slide show, size 3.30MB ?
Unless your picture frame supports Power point files you can't load it straight on to it, but you could try this.
Hope this helps
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
SOURCE: effective slides on paper presentation on wireless communication
Here are some templates to help you get started and give you some ideas.
http://office.microsoft.com/en-us/templates/CT101423491033.aspx?av=ZPP000
SOURCE: Cursure jumps while typing and I'm kicked out of PowerPoint slide show
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
44
The PowerPoint software program allows you to create slide presentations that can be viewed on any computer.
While some graphic artists specialize in developing compelling presentations, anyone can develop a PowerPoint slide presentation that is attractive and readable.
Follow these steps to develop your own slide show.
Open your PowerPoint program. When the dialog box opens, click on the "Blank Presentation" option.
Choose an "AutoLayout" format.
Begin with the title slide layout, which is the first one on the left. Click "OK," and you will have a title slide to work with.
Add text to your slide by clicking in the title text box and typing a title.
Do the same thing in the subtitle box.
Create another slide by clicking the "New Slide" button on the Common Tasks toolbar.
When the AutoLayout dialog box appears, choose a layout for this slide.
Keep adding new slides until your presentation is complete.
Move from slide to slide by clicking the button on the lower-right corner of the PowerPoint window.
Clicking the button with the upward-pointing arrows will take you to the previous slide, and clicking the button with the downward-pointing arrows will take you to the next slide.
Save your presentation. Click the "File" menu and then click "Save As."
A dialog box will appear, and you'll be able to type in a name for your presentation.
The presentation will be saved to your hard drive.
as for the kreb cycle disgram im not sure
hope this helps
