Question about Sharp LC 70LE640U AQUOS 70 1080p LED LCD TV
LED TV has a bad column of pixels alway stuck on red. what would i have to replace to fix this? sharp aquos LC-70LE640U
5 Related Answers
Anonymous
  • 182 Answers
SOURCE: Sharp Aquos LC-32D43U
on the rermote control look for the button with a tv screen outline, two lines going down with arrows pointing to the edges they are closest too. when youve pressed that a menu pops up and select full mode. hope this helps
Posted on Jan 26, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 15, 2009
gopakumarg43
  • 76823 Answers
SOURCE: How do you fix the led strip in a Sharp Aquos smart TV model LC-60LE810UN?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jul 09, 2015
gopakumarg43
  • 76823 Answers
SOURCE: How to reset my sharp aquos led tv LC-24LE155M
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 26, 2016
Sharp LC-46LE832U TV
Yes, it does exist!
Support Details LC-46LE832U - Sharp Electronics
www.sharpusa.com > Support
Home > Support > LC-46LE832U. LC-46LE832U AQUOS QUATTRON LED LCD TV ... Have a basic question about your Sharp product? Get started with the ...
LC-40LE832U ' LC-46LE832U ' LC-52LE832U ' LC ...
files.sharpusa.com > ForHome > LCDTVs > Manuals
PDF Consult the dealer or an experienced radio/TV technician for help. DECLARATION OF CONFORMITY: SHARP LIQUID CRYSTAL TELEVISION, MODEL LC- ...
AQUOS LC-46LE832U LED-LCD TV-LC46LE832U ' Eckley ...
www.eckleysappliance.com > Sharp-Electronics-LC46L...
On the LC-46LE832U, this technology is enhanced further with Quad Pixel Plus, which produces smoother lines by enabling the individual control of all 8-million ...
Sharp LC-46LE832U Manuals ' ManualsLib
www.manualslib.com > ... > Sharp Manuals > LCD TV
Sharp LC-46LE832U Pdf User Manuals. View online or download Sharp LC-46LE832U Operation Manual, Connection ... LIQUID CRYSTAL TELEVISION.
Somehow getting access to the actual internet on my aquos sharp TVLC
The TV will connect to your wireless router but not other devices in your network. You can connect to a HDMI port with a cable to your PC and select that port on the TV.
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
My Sharp aquos won't resond to remote
Replaced Battery of remote.keep your mobile camera ON and press any from remote.If you get flash light in camera that means your remote is ok. Checked & Replaced LED TV sensor pcb.
1helpful
Help, my Sharp LC-70LE640U turned of by itself after only a week of use.
If it is brand new, and under warranty period, it will be best to replace this TV. Check the site linked below. There are some details about these type of faults to Sharp LC series TVs. Blinking codes are also described in detail there. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
1helpful
Is it true that when one pixel goes out, others are soon to follow?
No, that's not true at all. Each pixel is its only little device - one pixel does not effect another. The pixels work together to make a picture, but are all controlled separately. If your pixel is "stuck" and not dead, then you may be able to fix it! A stuck pixel is red, blue, green or white, while a dead pixel will show up as black. Sometimes a stuck pixel can be fixed by covering a pencil eraser with a cloth and pushing down on the pixel gently while the TV is on. So, in summary - no, one bad pixel doesn't mean any other pixels are bad. Hope that helps, Alex
1helpful
Sharp LC 70LE640U AQUOS 70 1080p LED LCD TV Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
