Question about Schlage Locks & Locksmithing
How to drill out the schlage 595 key and kaypad entry
Posted by Allan Lawrance on
1 Related Answer
Coaltowner
  • 963 Answers
SOURCE: I need to set/change the code on my Schlage lock but the sticker is completely unreadable.
I do not believe you will be able to reprogram the lock without the programming code, usually found on the sticker (unreadable, in your case).
Therefore, I urge you to call Schlage directly-they may be able to help you. here is the contact information:
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
You are right about the support link going 404-It used to work. Get there by going to:Schlage.com
and clicking on "For your home"
Mouse over the "Service & Support" link, then go down & left click on "Instruction & Manuals". There ya go!
Posted on Feb 22, 2012
We have several Schlage keypad entry locks. The battery is dead on one lock and it is to the cupboard which contains the manuals, codes and emergency keys! How can we get the lock open or off?
Emergency Key Override.
If you are daft enough to keep the emergency keys on the room locked by the keypad, you need a locksmith and a pik set or pik gun. :>) Lesson learned.
Are you able to push the pins out on the hinges?
Here is the manual anyway.
http://consumer.schlage.com/project%20documents/23780042%20fe%20and%20be-series%20user%20guide-a_web.pdf
Nov 27, 2016 | Schlage Locks & Locksmithing
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
Can i purchase multiple keypad deadbolt with same key?
Yes, Thank you for your inquiry; At FactoryLocks.com we carry Schlage BE365PLY505. The key number is stamped on the key. You can purchase the same entry on our website, factorylocks.com with your existing locks key number. Enter the 5 digit key code on our shopping page that is on the key. We'll get it keyed and out to you quickly.
May 09, 2014 | SCHLAGE LOCK COMPANY Schlage BE365VPLY505...
How do i remove a schlage lock
Get an old chisel or very sharp small screwdriver. The screws are covered by a plug that has been hammered in.You will need to pry these out to show the screws.Rotating while prying is best.
Mar 12, 2014 | Schlage Keyed Entry and Double Cylinder...
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Need to find code for Schlage keypad door lock but the sticker behind the plate is unreadable. I do have a key.
I don't believe that you can do without the programming code found on the sticker.Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
I urge you to call and I hope that they can help you. Good luck!
Feb 15, 2012 | Schlage FE595VCAM716ACC Camelot Keypad...
Feb 14, 2012 | Schlage FE595VCAM716ACC Camelot Keypad...
Lost instruction book. Need to know how to chance codes
I'm directing you to this page, where you will be able to scroll down and find the information for your lock FE 595. Here you should find everything you need to know. Good luck!
Just cut and paste the link into your browser or type it in directly in the search bar.
Jul 14, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
When I punch in my code for my Schlage FE595, the code is accepted and the schlage key blinks, however, it does not allow for the unlocking or for me to open the door. Also, when I set my door from the...
You did not indicate whether this is a new installation that you are having difficulty with,but I'm going to assume that it is.
I'm going to direct you to a web page that has a wealth of information for the Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
This page has links to the PDF file of the installation instructions, which you should already have in your possession:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
Also, there are two videos that may be helpful in troubleshooting your problem:
Installing your FE 595 Keypad Entry Lock video:
And, Programming Your FE 595 Keypad Entry Lock:
The reason that I think it's a good idea to review these two videos is that again, assuming this is a new installation, is that you may spot a mistake in the initial installation process.
Was the "Thumbturn" in the proper position when the inside plate was installed? (Shown at the 5 minute mark of the installation video)
Also to be found on the Service Support page link is a link to Schlage's Service & Support
which will allow you to contact Schlage if the problem remains unresolved after reviewing your installation.
I hope this helped. Good luck!
May 20, 2011 | Schlage FE595-PLY-FLA FE595PLY620FLA...
Need to reset code. i know the cod now .just dont know how to enter new one
There's a video link on this page, under the FE 595 header:
Feb 05, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
Locks & Locksmithing Logo
219 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
