Question about Schlage Locks & Locksmithing
Lost key door locked schlage 595key and keypad all codes are gone and door is locked how can I open it
Posted by Allan Lawrance on
5 Related Answers
Anonymous
SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Posted on Sep 30, 2008
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: to drop my code and put a new code in my schlage keyless door loc
http://consumer.schlage.com/customerservice/pdfs/Programming_Deadbolt.pdf
Posted on Mar 13, 2009
Anonymous
SOURCE: Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
Posted on Jun 09, 2009
Anonymous
  • 384 Answers
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Posted on Jun 24, 2009
knite1
  • 16 Answers
SOURCE: Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Posted on Jun 21, 2010
Testimonial: "I will try your suggetion. Thank you."
I can't find the code for my schlage keypad lock. Is there any way to reset my passcode without the original code for the lock
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Feb 15, 2011 | Schlage Locks & Locksmithing
How do i change the code on this lock
Jan 31, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
How do I set the key pad to my on code on my schlage electronic keyless lock
This link will give you instructions for various models of Schlage locks, including the BE 365:
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I lost my instructions to change the keypad password, can you please instruct me on how to change this password?
Jan 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I would like to program the schlage deadbolt keypad using my personal code.
There is a video on that page.
Dec 18, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Instructions needed for changing the keypad combination of a Schlage Camelot Keypad Lock 26D. I lost the instructions. Please advise. Send information to [email protected]
Dec 17, 2010 | Schlage Locks & Locksmithing
Installation information. Thanks
Nov 28, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Manual for changeing code
Nov 12, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Locks & Locksmithing Logo
259 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
