SOURCE: Whirlpool Oven AKZ101/1X serial 858510115001 140349004758
Ensure the oven knob is set to 0 (zero) and press the reset button in the middle
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
SOURCE: Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
appliance parts, help &
more
SOURCE: oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
