Question about Samsung UN50EH5300 - 50" 5 Series LED-backlit LCD TV - UN50EH5300FXZA
My Samsung smart TV has sound but no picture. It lights up but won't show picture. It's a UN50EH5300
Posted by Steve Sheets on
Raymond
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Check the backlight if you have backlight only two things will solve the issue . The Tcon board board need to be changed. The other would be to get another main board those tow parts I mentioned will solve your issue would try the tcon board first
Posted on Jan 03, 2020
5 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: TV showing picture but no sound
Check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit which you will need new main board. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 03, 2010
SOURCE: Samsung B2330HD Blue Still light, no picture?
Hay Junior!
You have a power supply problem and unfortunately this repair sould be done by one who knows electronics specially tv electronics..
Posted on Jun 19, 2012
Igor Ceke
  • 125 Answers
SOURCE: my samsung smart tv won't connect to my network
You need to setup all you computer network to home network not public network because in order to connect you need to have a password which you need for every system in your home. Consider which computer is your main system. Then go to control panel and select networking icon and select network status. Now click on where it says Public Network or even Home Network and re choose home network and right down the code password. Then click ok and you are set. Go to your TV and choose to setup network, then choose to detect network automatically and choose your network. Then type in your password and you are set. Try it now and you should be able to view your photos, videos and so on. Good luck and let me know you you go!!
Posted on Sep 29, 2012
  • 18520 Answers
SOURCE: Samsung 50 Smart TV...Sound but no picture...Fuse? or Inverter? or what?
Look at the picture up close and with a flash light. If you can see images then it is the inverter
Posted on Sep 09, 2015
gopakumarg43
  • 76455 Answers
SOURCE: My Samsung smart TV the picture stopped working I have sound no picture
Check and replace the damaged components at its back light inverter circuit. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Posted on Jan 28, 2017
I have a 50 inch Samsung Smart TV UN50EH5300 that went dead...so I replaced the voltage supply board and it came on sound but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 29, 2016 | Samsung UN50EH5300 - 50" 5 Series...
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Movie picture does not fill screen
If it's an older movie it will not fill the screen . It was never meant to play on a wide screen TV so the only thing you can do is use the zoom and stretch features on your remote. You may not like the results.
Dec 21, 2015 | Samsung UN50EH5300 - 50" 5 Series...
Why is there sound but no picture?
Dec 05, 2015 | Samsung Electronics Samsung 50" UN50EH5300...
How do I fix my Samsung 40 LED TV that has sound but no picture?
When repairing LED TV Back light assembly you need to contact expert person because lifting of LCD TV panel is very dangerous for non technical person. Be careful
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Samsung curved tv no picture
Please give more details, does the power light come on, does it switch on but show no channels, does it not switch on at all? Please add detail and resubmit the post
Jun 14, 2015 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
Sound goes to 100% by its self
The pcb with the volume + & - and ch + & - is faulty. The easiest and cheapest way to repair this is to take the back off your TV and just disconnect the plug and socket on this pcb. The remote will work the TV as usual. Hope this helps
Feb 03, 2014 | Samsung Electronics Samsung 50" UN50EH5300...
My Samsung tv is old and the screen just won't
check whether the sound is there.
find out the picture tube filament is glowing or not. If it glow then you check the G2 voltage (<350v)
Increase the screen voltage on FBT and check the light come on screen or not.
Aug 24, 2011 | Samsung Televison & Video
Samsung UN50EH5300 - 50" 5 Series LED-backlit LCD TV - UN50EH5300FXZA Logo
235 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
