Question about Binatone Lands Phones
I have a binatone lifestyle single 1910 with caller display. I answered a call from a mobile and want the number. iv dialled 1471 and it said number was withheld but it was on screen
Posted by susan jackson on
5 Related Answers
wskanaan
SOURCE: Sony Ericsson K610i mobile phone
I had the same problem... it was solved for me by going into
Menu -> Calls -> More -> Delete All
I think the problem was that the missed and other calls were stored in the provider's server... and deleting each entry from the list was not deleting them from there, but instead just deleting the entry from my phone.. anyway... now it saves and shows the missed calls.
I hope this helps...
Posted on Oct 19, 2007
Anonymous
  • 11 Answers
SOURCE: Caller display not showing
you have to go on phone settings or call settings and it has an option for caller id on or off
Posted on Mar 20, 2009
Anthony Abbott
  • 136 Answers
SOURCE: Caller Id on outer screen does not display incoming caller
the LCD screen is broken
Posted on May 29, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Bose Lifestyle 48 Series IV
Here is the owwners manual you can register it if you like but it's a free download. http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/home_theater_system.jsp
Also here is thir worldwide support page for your product
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/worldwide_support/index.jsp
They have the phone number for support, I have owned many bose systems but not thiss one, seeing that you have had so many people trying to help I thought I would give you this information to contact their direct support By phone in the Morning, If it's flashing it's not getting a signal from most of bose products I have used so hope this helps and merry xmass hope ya get it fixed.
Posted on Dec 24, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: We bought my mother in
Hi.
Unfortunately the manual for this new model is not yet available in downloadable PDF format.
Here the manual for the 1810, that has the same functions and controls: User Guide
The manual for your phone can be obtained free of charge contacting Binatone here.
Regards.
G.
Posted on Aug 27, 2010
Please help I can't ring out on my phone
Check for dialing tone by pressing 'Talk On' phone button.
If no tone, check cord at base station and the phone socket is correctly plugged in at both ends using the original cord supplied.
If still no dial tone, check the phone at another phone connection to establish if either the phone or the line is faulty. Address for
Binatone support at this link: http://binatoneglobal.com/support/
Jun 28, 2015 | Binatone Lifestyle 1910 Twin Cordless...
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
How do I extend the ringtone time of incoming calls on binatone lifestyle 1910
Most of the newer phones have a feature that quiets the ringtone when you touch the phone or move it. You can deactivate this feature in the settings menu. I hopes this helps you..
Nov 25, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Why when I phone some one I can hear them but they cant heat me
You may have accidentally pressed the Mute button. Undo as below
Mute a Call:
You can talk to someone nearby without letting the caller hear you during a call. During a call: Press <C> t o mute the microphone and "MUTED" will display on the LCD.
Your caller cannot hear you. Press <C> again to unmute the microphone.
Nov 19, 2014 | Binatone Lifestyle 1910 Twin Cordless...
How do I increase the external ringing volume on a
Adjust Volume
There are 5 levels (VOLUME 1 to VOLUME 5) to choose from for the earpiece or speakerphone volume
During a call: Press <up/down> to select volume 1-5.
The current setting is displayed. When you end the call, the setting will remain at the last selected level.
Sep 21, 2014 | Binatone Lifestyle 1910 Twin Cordless...
How to extend ring
To extend the number of rings before your phone goes into the answer message option, change the settings for Answer delay option as described below.
You can set number of rings before your phone answer message kicks in. You can set answer message to begin after 2, 4, 6 or 8 rings.
1. Press <Menu> and up down to select ANS Machine
2. Press <OK> and <up/down> to select TAM Settings
3. Press <OK> and <up/down> to select ANSWER DELAY (OPTIONS: 2, 4, 6 OR 8 RINGS)
4. Press <OK> and <up/down> to select to select desired delay.
5. Press <OK> to confirm.
Aug 18, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
Mar 24, 2014 | Binatone Lifestyle 1910 Twin Cordless...
When I answer I can hear the person but they can't hear me
Ive got exact same problem and same phone! I hope there's a simple answer as my provider said I need to check its defo not the phone as if I call them out to check the line and it's actually the phone I get charged 99 pounds!! Eeek!
Sep 29, 2013 | Binatone Lifestyle 1910 Twin Cordless...
Lifestyle 1910 cannot hear the ringing tone
I Think may problem in your Phone....You can please Call the service provider........
Jan 23, 2011 | Cell Phones
Lands Phones Logo
43 people viewed this question
Top Binatone Lands Phones Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
