Question about Apple iPad Tablets & eReaders
I want to remove icloud activation from my ipad
Posted by fouti makosso on
Nate Towner
    New Friend:
If you want to bypass iCloud activation lock permanently, follow the steps below.
Step 1. Tap on the Menu, then go down to Applications and tap on it.
Step 2. Now tap on Crash. With this action, your iPad will reboot.
Step 3. When the iOS device restart, choose "Language and Country", press the "Home" button and tap on "More Wifi Settings".
Step 4. Tap on "i." and scroll down and tap on Menu under HTTP PROXY.
Step 5. Clear the address bar and tap on the Globe on the keyboard.
Step 6. Type in 15 to 30 characters randomly and type in "8888" in front of Port and tap on Back.
Step 7. Now again tap on Next.
Finally, keep sliding to unlock and click the language options for 2-3 minutes without giving your fingers any rest. This action will lead you to the home screen of iPad.
Now, you can access 3 applications - Phone, Newsstand, and FaceTime. But every time you open one of the apps, you need to restart the iPad.
If you need help to know how to bypass iCloud lock, there are also many paid unlocking services available online. You can choose the one that you trust and start to unlock the iCloud lock.
How to Bypass iCloud Activation Lock on iPhone
Posted on Mar 27, 2017
Lucky Okuomose
    New Friend:
  • 3 Answers
Steps to delete iCloud account on iPhone/iPad
  1. Tap on the Settings app and then scroll down to find iCloud.
  2. Tap on "iCloud" to open it.
  3. Scroll down until you find "Delete Account" and then tap on that.
  4. Tap on "Delete" again to confirm the deletion of the iCloud account.
Posted on Mar 25, 2017
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
Nov 12, 2017 | Tablets & eReaders
Remove activation lock on IPad Person who had the IPad is deceased
If it white screen you are screwed if you do not no the Apple ID
if you can access the screen you can google check Apple ID then type the serial number to heck if it iCloud lock you can find serial number or imei number back of the iPad or in sim try if it's 3G iPad then type in and see if the iCloud is locked or not if it's not you can restore Ipad by iTunes on your computer turning the iPad off by pressing holding the power button and in-certain the charge till iTunes logo pop up on your iPad and then on your computer then restore the iPad
Mar 29, 2017 | Apple iPad Tablets & eReaders
How can I bypass iCloud activation on iPad 2?
You can get some very simple steps in this blog that will help you to make your iCloud account secure: visit here:
Tips for Offering Security to Apple iCloud Account Unveiled
Nov 13, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
I bought an ipad 4 second hand, however i cant sign in with my icloud as the previous owners icloud needs to be activated and i cannot contact the seller. any suggestions?
New iCloud removal service available contact accessonesolutions.com for more details. Reported lost/stolen units not accepted.
Mar 07, 2015 | Apple iPad 4th generation
How do i bypass a icloud activation screen on ipad 2 reported lost
Unlock Timeframe: 7-15 working days
iPhone Carrier iCloud Activation (Clean Only) Choose an option... iCloud Activation (Clean Only) iPhone Model Choose an option... Choose an option... iPhone 6 Plus iPhone 6 iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPhone 4 iPad Clear selection
IMEI: Please add IMEI number which contains 15 characters only
Feb 22, 2015 | Apple iPad Tablets & eReaders
How can I activate an iPad mini that is iCloud locked
I would go to an Apple Store and ask for help.
kolbrun
Dec 22, 2014 | iPad mini Tablets & eReaders
Remove icloud completely off i pad
iOS
Tap Settings > iCloud. If you're using iOS 8, tap Storage > Manage Storage > Backups. ...Tap the name of your iOS device.Tap Delete Backup. When you're asked to confirm, choose Turn Off & Delete to turn off Backup and remove all backups for the iOS device from iCloud.
Sep 22, 2014 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
578 people viewed this question
Top Apple Tablets & eReaders Experts
 Larry
Larry
john smith
gaucherre
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
