SOURCE: no picture no sound
After taking the screws out and removing the back, you will see a power supply(where master switch and cord connector are). Remove the 4 screws on the aluminum cover plate to gain access to the fuse. Using a voltmeter, with the power on and switch on, measure the voltage on each side of the round fuse located just behind the cord connector. If voltage is 0, fuse is good. If voltage between 115 and 125 V, replace fuse or have fuse replaced. I think it is a 6.3Ah 250V class fuse that is soldered into the board. IF YOU ARE NOT FAMILIAR WITH SOLDERING TECHNIQUES AND PRECAUTIONS, DO NOT ATTEMPT TO DO THIS. IF YOU ARE NOT FULLY AWARE OF ALL SAFETY PRECAUTIONS NECESSARY TO MAKE THIS REPAIR HAVE A QUALIFIED TECHNICIAN DO IT FOR YOU!!!!!!
SOURCE: My olevia 237-t12 won't turn
It may abe in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
SOURCE: I have an Olevia 237-t12 hdtv, I will lose the
I had the same problem with the exact same TV. I took it to a local TV shop. My problem was fixed by replacing the T-Con controller board. The cost of the part was about $85 and labor $125. There are no "new" parts out there for Olevias because the company is out of business but I did find a part pulled from a "damaged in transit" TV. It's a personal decision (assuming the parts can be found) as to if its cost effective to repair the TV.
SOURCE: I need to mount my
Just measure the 4 monitng holes spacing on the back in millimeter to get the VESA number.
It should be one of these: http://www.mountcenter.com/VESA-Mount-Standards-s/367.htm
pattern.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
