Question about iHip Audio Players & Recorders
How do I turn ihip Bluetooth headphones into pairing mod
Posted by Jerry Eldridge on
5 Related Answers
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: Pairing bluetooth headphone and mp3 player
search for devices option and visibility!! plz rate this post
Posted on Aug 25, 2008
Anonymous
  • 3 Answers
SOURCE: Can't pair bluetooth headphones with Insignia Pilot MP3 player
the directions from Samsung to pair the headset was way off. You need to hold down the main button then turn on the headset. Only then will the headset go into pairing mode by maintaining a solid blue light. It took me a couple of days of troubleshooting and experimenting to realize this pairing method. I just hope that this problem is only due to my headset because I assume a lot of people who buy this headset and try out Samsung's directions will become very frustrated. I almost returned the product and I am sure many others would too.
Posted on May 31, 2009
Anonymous
SOURCE: Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Posted on Aug 19, 2009
Chris McWethy
  • 170 Answers
SOURCE: How do I pair insignia bluetooth headphone with
The Insignia headphones must be set to "pair".
With the headphones off, press and hold the power button on the headphones until the logo starts blinking red/blue. You are now in "pair mode". Have your Touch look for bluetooth devices and it should see it now.
Hope this helps!
Posted on Apr 14, 2010
Dave Campbell
  • 244 Answers
SOURCE: I just bought these side swipe ihip Bluetooth
I sounds like the battery has failed and will no longer hold a charge. Generally, the batteries are not replaceable.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Posted on Nov 20, 2014
3answers
Only the right earphone of my IHip completely wireless soundpods will charge/work
When I turn my sound pods on and then go to my Bluetooth options there to sound pod connections and each connection is for a different side of the pod by can only connect to one making only one work how do I sync them
Pairing zmax pro to ihip bluetooth speaker
Have you tried 0000 as pass code hope this helps Merry Christmas
2answers
Repair guide for ihip bluetooth headphones
Theirs a red light on my iHip earbuds that won’t go away and they won’t turn on nor connect. I think it’s because of the red light. What do I do?
How to replace battery for ihip Bluetooth headphones
Take apart the ear phone speaker housing that has all the buttons on it.You will need a soldering iron and lead free silver coreless soldering wire. Use the iron to melt existing solder that connects battery to pcb use a small amount of fresh solder to attach the new battery.
I recently bought some bluetooth Ihip headphones.They won't work
take them back where you bought them and get a refund or another pair
1helpful
2answers
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Top iHip Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
john h
Are you an iHip Audio Player and Recorder Expert? Answer questions, earn points and help others
