Question about Ps Televison & Video
My 2010 65" Panny switches off after an hour. I can turn back on but 10-15 mins later off it goes again..I'm thinking it's the PS board that is starting to fail but unsure? Any guidance appreciated.
Posted by Duncan Harding on
Marvin
    Top Expert:
  • Ps Master
  • 85,239 Answers
That guess is as good as any.
Posted on Mar 24, 2017
5 Related Answers
Anonymous
SOURCE: Acer AT3201W 32 in. LCD Television
I have exactly the same problem, my unit has been sent to the service centre 3 times already and they still haven't fixed it. It appears to be a main board issue. I will send it back again for servicing and will NOT take it back unless the main board is replaced.
Posted on Aug 09, 2007
Anonymous
  • 57 Answers
SOURCE: Mid2020
if this is a desktop: Did you check the power supply? try to replace it with a new one
Laptop: Try to run the machine without the battery plugged in....straight with the adapter....If the laptop still restarts...it's a manufacturing defect which should be replaced by the OEM.
Posted on Jan 18, 2008
whitehorse99
SOURCE: Medion Mid2020 MD-41060 Switches self off
You don't need to take it all apart to get at the heat sink.
Take the strip off under the display (slides too the left to unlock) remove the keyboard. You will see a metal plate that covers the fan. (the fan is fixed too this plate. Remove the plate and the heat sink is underneath. You will probably find the fins are packed with lint. If you take the heat sink out be careful of the display cable that is bent around it and regrease the cpu when you replace it.
Posted on Feb 05, 2008
Anonymous
  • 3 Answers
SOURCE: Making Loud noises
sounds like the yoke on us. yoke is what makes that nosie.
Posted on Sep 13, 2008
SOURCE: Samsung LCD TV not switching on, but just clicks away.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jan 05, 2012
My tv loses picture and sound after being on for 3 to 4 min.
If you have a smart tv and you have a pair Bluetooth device in the house turn on. It could be paired, thus turning the sound on to the Bluetooth device.
Otherwise you have a faulty video or processor board, or which ever board control the sound.
May 27, 2015 | Televison & Video
Screen goes black and nothing work, what can I do?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 19, 2015 | LG 55LH40 55 in. LCD HDTV
My Sony Flat Panel Display FWD-50PX2A : When I plug in my Sony the green light goes on a ticking noise appear and after a couple of seconds the red light goes on - neither the remote or manual buttons...
Unplug,replug tv back in an hour later.Tv now reset it self back to factory setting.Now it should work.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 13, 2010 | Sony FWD-50PX2 50 in. Plasma Television
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Tumble dryer not working
Spoke to my maintenance engineer at work and he said that most of these appliances work by using float switches. After stripping down and drying out the previous day decided to refill reservoir with water and letting drain back in refilled again 15 mins later till no more water could go back in. Then emptied water reservoir and let the water drain back out into reservoir. Think this must have dislodged the float switch and all seems back to normal.
May 25, 2009 | Electrolux Dryers
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
PS 2 will not turn on
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 24, 2007 | Sony PlayStation 2 (PS2) Console
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Aug 06, 2007 | Acer AL2671W 26 in. LCD Television
Televison & Video Logo
27 people viewed this question
Top Ps Televison & Video Experts
Marvin
Marvin
Are you a Ps Televison and Video Expert? Answer questions, earn points and help others
